Old 05-31-2014, 03:37 AM   #1
Ianrhall
Default Lowering a 53
Just wondering about the best way to lower a 53 ford
The rear seems straight forward, 1-3" lowering blocks
At the front, I could
Fit lowering kit from butchscoolstuff-gives 2" drop, if that's too much I assume I could have the blocks machined?
Cut stock springs
Fit lowered springs
Fit Aerostar springs
I am only looking for 1-1/2" drop and want to maintain a good suspension(cut down new springs on my falcon and ended up with very hard ride!)
Thanks
Ian
Ianrhall is offline   Reply With Quote
Old 05-31-2014, 04:21 AM   #2
tubman
tubman's Avatar
Default Re: Lowering a 53
I put a set of Aerostar springs in my '51 and am very happy with all aspects of the change. It brought it down as much as I wanted, and there seems to be no difference in ride. The handling is much better than before, but that may be because I had it aligned after I put the springs in. It was less that $100 including sway bar bushings and spring isolators. I am not a fan of "in the weeds", so it may not be enough of a drop for some.
Old 05-31-2014, 04:29 AM   #3
JeffB2
JeffB2's Avatar
We have had a bunch of guys do the Aerostar spring swap here: http://www.jalopyjournal.com/forum/s...ial-group.282/ The ride and handling is really improved check out the price: http://www.summitracing.com/parts/mog-cc850 This is the matching shock to work with the springs: http://www.summitracing.com/parts/gab-82026/overview/
JeffB2 is offline   Reply With Quote
Old 05-31-2014, 07:13 AM   #4
49 Spinner
49 Spinner's Avatar
I've been thinking of doing the same on my 49 shoebox, I was thinking of putting Posies super slide dropped springs in the back instead of blocks, seems like a smoother ride, has anybody used them.? From what I have read the Aerostar coils work great.
RB
49 Spinner is offline   Reply With Quote
Old 05-31-2014, 09:14 AM   #5
Johnnydidd
Johnnydidd's Avatar
My 53 is lowered by using a spacer, remove the rivets that hold the front springs on the bottom, make a spacer the amount you want to lower mine is 1x1 flat bar, drill the holes the same as the bottom plate, use bolts to put back, drives the same as before. That way if you want to put it back, just remove the spacer. John
Johnnydidd is offline   Reply With Quote
Old 05-31-2014, 09:29 AM   #6
flatford8
flatford8's Avatar
Jamco Suspension sells as complete kit, front and rear. I just ordered for my '51.
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 05-31-2014, 01:37 PM   #7
Ianrhall
Those springs from summit, how much will they lower it, I'm only looking for 2" max
Ian
Old 05-31-2014, 03:07 PM   #8
tubman
tubman's Avatar
Check for yourself. I got my springs from Amazon.com (for more than they are from Summit), but they are the same Moog springs.
Old 05-31-2014, 03:39 PM   #9
Ianrhall
Looks good, what did you do to the rear?
Ian
Old 05-31-2014, 03:44 PM   #10
Ianrhall
Anyone have a summit link for the spring isolators?
Ian
Old 05-31-2014, 05:04 PM   #11
Alaska Jim
Alaska Jim's Avatar
do you guys think that the aero-star springs would work on a 51 Merc.?
Alaska Jim is offline   Reply With Quote
Old 06-01-2014, 04:43 AM   #12
tubman
tubman's Avatar
Ian
The rear spring shackles had been pulled "up". I put them back to normal. I am considering 2" blocks for the rear. I got my isolators frpm Bob Drake.
Old 06-17-2014, 05:34 PM   #13
Ianrhall
What thickness are the axle tubes on a 53 ford, wondering if I need a particular type of u bolt/lowering block kit, think the ones over here(UK) might be too small
Thanks
Ian
Old 06-17-2014, 05:35 PM   #14
Ianrhall
Should have mentioned, the car isn't here yet,hopefully on a ship soon!
Ian
Old 06-17-2014, 06:30 PM   #15
Johnnydidd
Johnnydidd's Avatar
I am removing my lowering blocks and u bolts off my 53 victoria it is lowered 2 inchs in the rear and one inch in the front, make you a deal on the lowering kit. I am raising it back up on account of the ride, I will replace all the shocks and anything that may be worn. It keeps botting out.
John
Old 06-17-2014, 10:14 PM   #16
TJ
TJ's Avatar
If you lowered the rear and didn't change the shocks(to shorter shocks) it will most certainly bottom out on the shocks.
Old 06-18-2014, 01:20 AM   #17
JeffB2
JeffB2's Avatar
Thanks
Ian
Your Ford has a 2 1/2" wide leaf spring the blocks should match many aftermarkets are 3" so measure before you buy.
Old 06-18-2014, 01:21 AM   #18
JeffB2
JeffB2's Avatar
Yes,it been covered on the HAMB many times.
Old 06-18-2014, 01:26 AM   #19
JeffB2
JeffB2's Avatar
Correct part numbers foe 1952-56 Fords lowered 2"-3" Gabriel (F)82026 (R) 81270 KYB's (F) KG4503 (R) KG5517
Old 06-18-2014, 01:57 AM   #20
Ianrhall
Good tip about the shocks, hadn't realised they had to be changed too, are those part no,s from an alternative car too?
Ian
