Old 04-08-2014, 08:44 AM   #1
Classiccanuck
Classiccanuck's Avatar
Default anti squeak?
I'm in the process of bolting the rear centre panel to the rear quarters on my '28 phaeton, when I took it apart I noticed what looked like hockey tape where the panels meet together, I would like to know what type of products you have used to assemble panels together, does it serve as an anti squeak material? I noticed traces of it where sheet metal meet in other places too. I would like to also use some on the floor pans to keep out fumes. Look forward to your comments, Thanks!
Classiccanuck is offline   Reply With Quote
Old 04-10-2014, 07:31 PM   #2
eystein
eystein's Avatar
Default Re: anti squeak?
No responses on this?
I too would really like to know exactly where Ford used anti squeak material?
eystein is offline   Reply With Quote
Old 04-10-2014, 08:30 PM   #3
wrndln
I used friction tape between metal to metal and metal to wood joints. Friction tape is real close to what Ford used originally, plus it isn't too thick. The problem is that friction tape only sticks to itself and even that does not hold all that well. To stick the friction tape to the metal or wood, I used contact cement on both surfaces to be bonded. It work well. I am posting a couple pictures of some of what I did.
Rusty Nelson
Old 04-10-2014, 11:19 PM   #4
ford3
duct tape works good, its tough and wont wear thru quickly
ford3 is offline   Reply With Quote
Old 04-11-2014, 06:40 AM   #5
Classiccanuck
thank you EYSTEIN, I was beginning to wonder.
Old 04-12-2014, 06:22 PM   #6
Classiccanuck
not sure about the duct tape, I find once it gets a few yrs old the adhesive begins to deteriorate.
Old 06-01-2014, 12:48 PM   #7
swo4rd
swo4rd's Avatar
Classiccanuck, everywhere on the model a that metal touched metal, there was anti squeak material: Friction tape, Gilsonite impregnated cotton webbing, rubber pads, wooden blocks...lacquered cloth beading and wood blocks.
What did you do?
Swoff
swo4rd is offline   Reply With Quote
Old 06-01-2014, 02:00 PM   #8
Mike V. Florida
Mike V. Florida's Avatar
Friction tape, hockey tape was used where wood meets metal on the cars I have seen.
Old 06-01-2014, 02:06 PM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
So true, and not only the adhesive, but the plastic tape itself breaks down. Friction tape would be much better.
Old 06-01-2014, 02:33 PM   #10
Purdy Swoft
Purdy Swoft's Avatar
The model A catalogs should list the welts that are offered, Brattons or Snyders are a good place to look. You sure don't want something that would hold moisture between the panels .
