Old 05-10-2014, 03:56 PM   #1
quickchange
quickchange's Avatar
Default 29 closed cab measurement
Would someone be so kind as to measuring from the back of the cab to the front of the seat riser or from firewall back to front of seat riser please , Working on one that has new seat riser & sub rails so no marks where to fit , also is there a middle x member that rear of seat riser fits too plus seat wood supports , picture would be great , Thanks in advance , Derek T
quickchange is offline   Reply With Quote
Old 05-11-2014, 01:15 AM   #2
SeaSlugs
SeaSlugs's Avatar
Default Re: 29 closed cab measurement
i should be able to get one tommorow.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 05-11-2014, 02:06 AM   #3
pooch
pooch's Avatar
Derek, both measurements are to front edge of seat riser horizontal to the chassis.
This is 617 mm from this position on back wall.
This is 702 mm back from this position on firewall.
My cab is original and vertical door and bonnet gaps are very good, so see if your cab tallies 1319 mm from front to back and compare.
I believe the guy who did these back wood uprights made them from pics.
There is a wood section that goes across from side to side in middle under seat to support it, but I don't have that in.
pooch is offline   Reply With Quote
Old 05-11-2014, 03:06 AM   #4
quickchange
Pooch, thanks will check in morning , I see my new seat riser is differant than yours as mine does not have the rear section, Just as i thought there was a piece missing , also the new floor pan under the seat they supplied does not fit being too wide & too long , Im sure i can now figure it out , Thanks again for the help,
