Old 03-31-2014, 10:31 AM   #1
V4F
V4F's Avatar
Default cabrolet header
has anyone got pix or info on how the header & windshield install . yes I asked this once but still need help ............
V4f
V4F is offline   Reply With Quote
Old 03-31-2014, 11:20 AM   #2
jw hash
jw hash's Avatar
Default Re: cabrolet header
is it a 68 B or C there is a big difference.
jw hash is offline   Reply With Quote
Old 03-31-2014, 11:56 AM   #3
V4F
V4F's Avatar
how do I tell . it is a friends .............. thanks
V4f
Old 04-01-2014, 08:21 AM   #4
jw hash
jw hash's Avatar
does it have a slanted windshield or is the windshield straight.
Old 04-01-2014, 09:02 AM   #5
V4F
V4F's Avatar
straight . thank you
V4f
Old 04-01-2014, 01:03 PM   #6
V4F
V4F's Avatar
any help on this ? need a pic if possible
V4f
Old 04-01-2014, 01:08 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
I don't have a link, but have you been to Kevin in New Jersey's site?
Old 04-01-2014, 01:11 PM   #8
V4F
V4F's Avatar
no tom I haven't . any help on finding him ? thanks
V4f
Old 04-01-2014, 01:31 PM   #9
jw hash
jw hash's Avatar
the windshield header is part of the cowl section. it takes the same rubber seal as a coupe and other Model A`s and then the upper hinge is screwed in with 1/4-20 X 5/8" stove bolts or slotted screws for better word the upper hinge is the same as a lot of Model A`s but the outer two screws are located in a different location so if are using one that does not fit you will have to drill the hinge. if you are looking for the seal that is fasten to the bottom of the top header, I purchased mine from Larry Machacek in Texas
Old 04-01-2014, 01:35 PM   #10
V4F
V4F's Avatar
thank you . my problem is none of the windshield screw holes line up with anything .......... steve
V4f
Old 04-01-2014, 02:28 PM   #11
Bruce Adams
Bruce Adams's Avatar
I have a 68C / slant windshield and will be pleased to assist if I can understand your situation.
Is it about attaching the whole windshield to the Cabriolet's header?
What are YOUR distances, edge to hole, and hole to hole?
Bruce Adams is offline   Reply With Quote
Old 04-01-2014, 04:03 PM   #12
fcwilkie
I had the same problem with my early 68B - bought a new windshield and the holes did not line-up with the threaded holes in the cowl. Called the manufacturer of the windshield and he simply said that Ford was not consistent with the threaded hole spacing and further said he had run into this before but it was rare. I took him at his word and ended up redrilling the holes in the hinge. Good luck
fcwilkie is offline   Reply With Quote
Old 04-01-2014, 05:04 PM   #13
V4F
V4F's Avatar
im going out tomorrow to get a better look & pix . thanks all . maybe after tomorrow ill have better info ............ steve
V4f
Old 04-01-2014, 06:45 PM   #14
jw hash
jw hash's Avatar
if you have a slant window upper hinge NONE of the holes will line up on a 68 A or B also the slant window hinges will have a deeper off set. you need to use one off a coupe tudor truck or sedan but not a slant window.
Old 04-01-2014, 08:17 PM   #15
LopezCarguy
LopezCarguy's Avatar
I have a 68A early and window frame to header was just screwed to windshield frame from above under header seal...not complicated...can supply which screw was used...
The only thing worth learning is what you learn after you know it all !!
LopezCarguy is offline   Reply With Quote
