Old 03-05-2014, 09:13 PM   #1
louieglen
Default Valve guide removal
How is the best,"easiest" way to get valve guides out without the removal tool. Can I make a tool? Thanks in advance.
louieglen is offline   Reply With Quote
Old 03-05-2014, 09:25 PM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Valve guide removal
A bent screwdriver but don't expect to use them again and there is a high risk of damaging something. Get the right tool.
Old 03-05-2014, 09:26 PM   #3
Mitch//pa
Anything can be made at what cost of time.
The tool is 19.95
Old 03-05-2014, 09:59 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
The tool Mitch shows is the ONLY good way to do the job. Be sure to use a punch placed exactly in the center of the valve, so you don't bend the stem.
There are also some factory made tools that curve around the valve head, but they often have too much spring to get the really tight valve guides out.
Old 03-05-2014, 11:47 PM   #5
700rpm
700rpm's Avatar
Just buy the tool. You'll need it more often than you think. You can mouse around with screwdrivers and punches and such, but jeez. $20? With the right tool you minimize the chance of doing more serious damage to the guides and block. Do it right, and do it once.
Ray Horton, Portland, OR
Old 03-05-2014, 11:53 PM   #6
Al 29Tudor
Al 29Tudor's Avatar
I was able to remove the retainer and spring and push the valve up as far as the mushroom allowed and use a large screw driver to tap them down into the chamber below.
Al 29Tudor is offline   Reply With Quote
Old 03-06-2014, 12:55 AM   #7
Drive Shaft Dave
I own both style's of the valve guide tool's, the newer version work's best.
Drive Shaft Dave is offline   Reply With Quote
Old 03-06-2014, 02:55 AM   #8
CarlG
CarlG's Avatar
I have the tool shown by Mitch in Post #3. Made getting mine out very easy.
Isn't owning a Model A just an excuse to buy more tools? I always thought it was!
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-06-2014, 07:29 AM   #9
Joe K
Joe K's Avatar
This works and how I currently do it. If one is UBER careful one won't damage the nose of the guide where it comes into the passage. It helps to know the orientation of the "split" and catch the nose at 90 degrees to the split.
Still, the Tim Allen excuse rules.
Joe K
Shudda kept the horse.
Old 03-06-2014, 12:33 PM   #10
Mark W.
Mark W.'s Avatar
I agree on both accounts above (Books too) but for some people they would rather risk damage than "waste" 20 bucks...
I have a tool similar to the one above made by GEM I think - found it at a yard sale for $0.25 and I also have a bent rod style made by Walden somewhere that came to me the same way - if I can find both I'll post pictures. Helps to know what you are looking for.
Mark W. is offline   Reply With Quote
