Old 03-04-2014, 12:56 PM   #1
BarracudaBoy
Default Model A Ford Oil Pump Shield
Going to get my engine rebuilt. What's the story on this Oil Pump Shield? Should I get one and install it since I'm redoing the engine? How does it work? Anyone have a picture of it installed down in the oil pan? Does the dip tray need to be modified?
BarracudaBoy is offline   Reply With Quote
Old 03-04-2014, 01:15 PM   #2
CarlG
CarlG's Avatar
Default Re: Model A Ford Oil Pump Shield
Here's the way it goes in:
(see also this string for more info: https://www.fordbarn.com/forum/showthread.php?t=132923 )
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-04-2014, 01:26 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
Yes;
“Under no circumstances install an oil shield without installing the new oil pan or vice versa”.
“The oil pan tray (A-6688) has also been lowered 1/8”. This has been accomplished by correspondingly raising the height of the bead in the oil pan tray”.
Old 03-04-2014, 01:54 PM   #4
BarracudaBoy
So trim 1/8 off the bottom of the shield?
Old 03-04-2014, 04:24 PM   #5
Steve Plucker
Call Bert's in Denver...They will more than likely have an original that you can use...Both the tray and the shield. Study the Ford Service Bulletin pertaining to the shield and the tray.
HOWEVER...I believe it must be installed with the oil pump that has the bolt-on cover.
Pluck
Old 03-04-2014, 08:36 PM   #6
Gary WA
Gary WA's Avatar
Originally Posted by Mike V. Florida View Post
Yes;
if removing the shield and installing a rebuilt pump is the pan OK to use?
www.whidbeymodelaclub.com
Old 03-05-2014, 09:14 AM   #7
Mike V. Florida
Originally Posted by Gary WA View Post
is removing the shield and installing a rebuilt pump is the pan OK to use?
Sure.
Here is the thread as Carl mentioned above. It explains what was done and why.
