Old 02-26-2014, 06:39 PM   #1
Jim Mason
Jim Mason's Avatar
Default oil can
I've been looking for the description of the oil can holder for the ve and e28's. I've seen a bent wire version, and a bent sheet metal. I don't seem to find it in the standards....
www.jmodela.coffeecup.com
Fwiw, jm.
Jim Mason is offline   Reply With Quote
Old 02-26-2014, 07:36 PM   #2
Russell in Tulsa
Default Re: oil can
Wasn't that a "T" option. Don't believe it was intended for the "A" but could be a dealer option and therefore not in the standards?
Russell in Tulsa is offline   Reply With Quote
Old 02-26-2014, 07:47 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
Default Re: oil can
The first few hundred might have had them like the open ended bumpers.
Old 02-26-2014, 07:54 PM   #4
John Stone
John Stone's Avatar
Default Re: oil can
There was never a part number for an oil can holder. I don't believe Ford ever supplied one, even for the T. I have seen them on REO trucks.
John Stone is offline   Reply With Quote
Old 02-26-2014, 09:52 PM   #5
al's28/33
al's28/33's Avatar
Default Re: oil can
It was on the T but I made a special bracket to hold one onto the firewall/gas tank bolts just above the steering column on the "A" and it gets attention!
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 02-27-2014, 07:29 AM   #6
Mark W.
Mark W.'s Avatar
Default Re: oil can
Here is the one I used to cover up holes from a starter solenoid - it is from a mid 20's Studebaker and is similar to repops.
Mark W. is offline   Reply With Quote
Old 02-27-2014, 09:26 AM   #7
John Stone
John Stone's Avatar
Default Re: oil can
Do you have the T part number for the bracket?
Thanks
John
Old 02-27-2014, 09:41 AM   #8
jkeesey
jkeesey's Avatar
Default Re: oil can
Heres one available.
http://www.snydersantiqueauto.com/1730
jkeesey is offline   Reply With Quote
Old 02-27-2014, 10:40 AM   #9
al's28/33
al's28/33's Avatar
Default Re: oil can
My Dad made the bracket special for me, it's not a factory made part.
Old 02-27-2014, 11:16 AM   #10
Mike V. Florida
Default Re: oil can
Further investigation leads me to the understanding that on the Model T it was an accessory not a standard feature to have it mounted in the car.
Modeltman posted
"Yes, the bracket is just an accessory, made non-Ford, show judging requires the Model T to only have the factory tools. Now that oil can is factory Model T, but it was supplied in a box of tools and a tool roll with each car. Never was mounted to the car. The owner would do what he wanted."
on this thread,
https://www.fordbarn.com/forum/showthread.php?t=23516
Old 02-27-2014, 11:51 AM   #11
Bruce Lancaster
Default Re: oil can
A very nice bracket with a nicely designed set of spring loaded clips is available in repro from any of the many places that supply repro parts for WWII Jeeps. Tell them to send one for your GPW...that way it's a Ford part!
Old 02-27-2014, 07:00 PM   #12
1931 flamingo
1931 flamingo's Avatar
Default Re: oil can
Sooo, to install brkt and oil can I'm going to have to drill holes in the firewall??
Paul
Old 02-27-2014, 07:29 PM   #13
Purdy Swoft
Purdy Swoft's Avatar
Default Re: oil can
Gas light auto parts in Ohio use to sell the oil can brackets and oil cans with Ford script, probably still do. I bough a couple of them in the ninties. I've got an older oil can bracket somewhere in my stuff, may be in the shop. I will check tomorrow. If I find it and it has a number I will post it.
Old 02-27-2014, 08:52 PM   #14
al's28/33
al's28/33's Avatar
Default Re: oil can
DON'T DRILL ANY HOLES!!! You can use the gas tank mounting bolts along the fire wall to mount your bracket or get an extra piece of metal to bend around that lip.
Old 02-27-2014, 08:53 PM   #15
al's28/33
al's28/33's Avatar
Default Re: oil can
