Harbor freight sells a tool like this. Has anyone used one or similar?
https://www.youtube.com/watch?v=mwzwboqN5Cw
Nothing wrong with it except for the name on the front. Alex |
I have one and it works well. When working with fins I will say that patience is a virtue. Steady as she goes. I have also seen long nose pliers with the tips ground (home made) to appear like a duck bill for those fins really laid over.
I have always used old hacksaw blades......the rounded end and the straight back.
Those combs are sized for condenser fins, the one I picked up did not match the fin count on either my '36 or '47 Ford radiators.
I had better luck using a straight slot screwdriver and a ground down duckbill pliers. |
I used to sell them years ago when working at a Ford heavy truck parts department. There were different sizes for fin variations on radiators, A/C condensers etc. Haven't seen any like the kind I sold for a long time. Can't remember who I got them from probably the radiator shop that did our radiator recores & repairs. We also called them radiator combs.
to "shrink" the fin material. This is the same idea as the pliers used on stove pipes for the female ends of a connection only much smaller crimps. G.M.
www.fordcollector.com |
I bought one from my snap-on dealer. works pretty well, but depending on how bad things are bent a pair of duck bill pliers and a modified needle nose, are good to have.
Looks good enough for a modern throw-away radiator, but for an irreplaceable antique radiator? Not on your bippy.
Alan |
Count the number of fins you have per inch.just hold a tape vertical and measure 1"and count the amount of fins you have in that 1". There are several fin combs out there that are made for condensers.
