Old 02-09-2014, 09:03 PM   #1
Tony S,Fl.
Tony S,Fl.'s Avatar
Default Distributer oiler.
Is the oiler press fit or threaded ? Tony
Tony S,Fl. is offline   Reply With Quote
Old 02-09-2014, 09:08 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Distributer oiler.
Press fit.
Stick a punch down inside the hole after pulling back the slide-cover. Twist the punch and the oiler will/should slip out of the housing.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 02-09-2014, 10:35 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
I put a punch in the oil hole as Brent said, then I use a flat blade screwdriver behind the punch to pry it out. This way there is no chance of deforming the oil hole.
Old 02-09-2014, 11:56 PM   #4
Mike V. Florida
Mike V. Florida's Avatar
Originally Posted by BRENT in 10-uh-C View Post
Press fit.
Were all the oilers the same that were supplied from Ford? I have seen, and thought, that the 31 style had a flip door oiler instead of the pull out style oiler.
Old 02-10-2014, 12:20 PM   #5
jm29henry
jm29henry's Avatar
Brent and Tom are two really smart gentlemen!! thanks for always helping all of us.
jm29henry is offline   Reply With Quote
Old 02-10-2014, 04:32 PM   #6
ursus
I have seen Model-A replacement distributors with the flip-door oiler but do not believe they were a Ford product. I have a new in the box version sold by Western Auto back in the day. They basically replaced the spring-loaded pull type oiler with a flip-door oiler as was used on the generators. Oiling these is a bit messier but with a syringe you can fill up the shaft and bushing area with a pretty good shot of oil.
