Old 01-28-2014, 11:08 AM   #1
CrownVic55
CrownVic55's Avatar
Default Wheels
I have a set of wheels supposedly from a 1953 Ford. They have riveted centers to rim. Will these rims be compatible with tubeless tires or will only welded wheels work?
Thanks,
Ben
CrownVic55 is offline   Reply With Quote
Old 01-28-2014, 11:37 AM   #2
jkeesey
jkeesey's Avatar
Default Re: Wheels
Should be fine. I used a set of 51 Merc wheels like you describe. We added silicone around the rivet heads just as a precaution.
jkeesey is offline   Reply With Quote
Old 01-28-2014, 02:27 PM   #3
Motorhead6
Default Re: Wheels
My '51 Ford wheels work fine with tubeless. However, my '55 Ford wheels are 1/2" wider than the '51. You may want to check this.
Motorhead6 is offline   Reply With Quote
Old 01-30-2014, 06:57 AM   #4
mercman from oz
mercman from oz's Avatar
Default Re: Wheels
1951 Mercury Wheels have a different Bolt Pattern to the Fords. Fords started their Bolt Pattern back in 1949, but the Mercury continued on with the old Ford Bolt Pattern through to at least 1951. We don't see many of these cars in Australia.
