Hey guys,
I was wondering what, if any differences there were between 28 and 29 grille shells and hoods for passenger cars. Open cars, if it matters. And if AR's (E28's) had a different hood or grille than standard A's in 28. Any info would be appreciated! Thanks! S |
The very early 28's have the hood lacing woven between holes in the shell like the Model T, all others were riveted. The crank hole molding at the bottom was a circle for '28, in '29 the molding contoured slightly to the bottom of the shell like a bell.
1928 "A" Phaeton (mid year with many early features) 1933 "V8" Closed-Cab Pickup Truck (originally a Model B, 4 Cylinder dating to May, 1933)
#3 | |
![]() Quote:
How about the hood? Number of louvers and placement the same? I was thinking that the louver layout was different between hoods, and maybe even more different for the AR. |
hood louvers parallel the top line I'm sure there are pictures on the internet and the four door sedan had a moulding along the hood sides that matched the cowl and body line special only to that body.
There is also a difference in the hood latch clips riveted to the louver sides - 28's were rounded on the 3 corners and 29's had sharp corners. There are pictures in the Judging Guidelines showing the two styles. There is also a picture showing the early hoods with the louvers parallel to the top hinge and the later hoods in the JG's that Al described above.
Rusty Nelson |
Great info!! Thanks guys!! Anything else?
I'm mostly trying to decipher what would look correct on a very early '28, but the car will not be 100% AR. If I can get away with a standard 28 grille shell and hood, I would like to. |
Unless you want to pay big time, the very early radiator shells with the lacing weaved into the shell are quite expensive as they don't come along often. Most I have seen on eBay are in the $500 to $1000 range. I don't know if they sell for that much or not. In fact, there is one on eBay right now for $995. I doubt it will sell for that price, but I am watching it to see what happens. Also, the hoods with the louvers parellel to the top hinge are also very hard to find. I beleive most of the early hood had 4 rivets attaching the handles verses the handles with the holes in them like Fred mentioned above. I believe only the very, very early hoods used the handles with the holes in them. I believe the information I stated above is correct, but if no, maybe someone will correct it.
Rusty Nelson |
The later hood and shell will work fine for you. The only one that would notice will be you of course and someone that is really an early enthusiast. I happen to have one of the early cars but unless you are really telling someone what month it was built it won't matter. Get it on the road and enjoy the fun!
#10 | |
![]() Quote:
give us some information,...please. 1. Frame number and engine number( if the engine is original to that car ). 2. Is there a gas tank number? 3. Photo of the lower firewall,...where the hood meets the firewall. 4. Photos in general of the car, including some interior shots With this information we can date the car...close to the month(s) it was made. Dudley |
#11 | |
![]() Quote:
#12 | |
![]() Quote:
I haven't posted any threads about the car yet, as it's not really a car yet. The car of topic will ultimately be a 1927 roadster on a 1928 frame with engine number 415. Will simply be a collection of parts mostly from 1927 and 1928, but sort of building it around the #415 engine, which is why the request for AR information. Sort of the idea that the car could have started life in late 1927 with a remaining Roadster body. The car will not be a restoration, but in fact a period correct, pre-war, purpose built race car in honor of the man (neighbor and friend) who passed and had dreams of building such a car. He had an early 1928 Roadster with several AR parts, but I do not think it was an actual AR. So I'm doing it the way he talked about. |
#13 |
Is it possible to modify a later shell to look like an earlier one? Can you post photos-I'd like to learn the difference. Thanks.
#14 | |
![]() Quote:
and the block number, please. The early guy's like looking at the parts,...the BIG plus is, adding another early number to the list! |
#15 |
Here's a couple of photos that might help you. The first is a '29 Model A hood showing the hood louvers parallel to the ground. The second is a '28 Model A hood showing the louvers not parallel to the ground.
Fred
Fred Carlton Life Member AACA 44 year member MAFCA Editor of The Restorer magazine, official publication of MAFCA 12 years Life Member Dallas Model A Ford Club (44 years) 23 year member & founder Lone Star Model A Ford Club Chairman 35th Model A Ford Texas Tour 1998 (state convention) Chairman 42nd Model A Ford Texas Tour 2005 (state convention) Charter Member Ford Model AA Truck Club If you aren't driving your antique car frequently, you might as well be collecting clocks!!! |
#16 |
Go to this link where Tom Wesenberg showed a closeup of the differences in the crank holes in the '28 and '29 radiator shells. It's in post number 3. It's easy to spot the bell shape around the crank hole on the '29 vs the '28 round/oval embossing.
Fred https://www.fordbarn.com/forum/showth...radiator+shell
#17 |
Not sure what you mean by being not parallel, is the spacing between the hood joint and the top of the louvers different from back to front?
#18 |
#19 |
Keep the pictures and info coming. Thanks guys!
I'll try and get some pictures of the engine. I need to get them for another gentleman here who started a thread looking to locate early engine info. The frame is not in my possession, at the moment. And i'm guessing the frame is not an AR frame. The body is in a million pieces and in storage. I have a long list of parts I still need to acquire for this project, so there's not much to see, yet. I'll certainly start a thread when it's all sitting under one roof in one pile. |
#20 |
Was the 1928-29 Fordor hood totally unique or will the other common sides fit the Fordor tops? Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical. |
