Old 08-28-2010, 10:23 AM   #1
pdora
pdora's Avatar
Default Battery cable
What gauge battery cable is required for a 6-volt system?
My recently-acquired 1930 Tudor has rather skinny-looking cables, and the starter seems sluggish, even with a new battery fully charged (as determined by a hydrometer test of all cells).
Thanks
Peter A. Dora -- Rutledge, GA (AE4XH)
pdora is offline   Reply With Quote
Old 08-28-2010, 10:31 AM   #2
billwill
Default Re: Battery cable
at least o or1cable for 6 volt system
billwill is offline   Reply With Quote
Old 08-28-2010, 10:34 AM   #3
Jim Baskin III Pa.
Jim Baskin III Pa.'s Avatar
Peter,2/0 cable works well for me.Welding supply sales has that size cable and the eyelet end if you cannot find it at your local auto parts supplier.I agree with you the as the small 12v cables will cause the starter to turn over slow and they heat up quickly.As a note make sure all connections are clean and tight,but I suspect you already know that.
Jim Baskin III Pa. is offline   Reply With Quote
Old 08-28-2010, 11:00 AM   #4
PC/SR
While you are at it, put in a full size cable to an engine ground. The transmission bolts are handy.
PC/SR is offline   Reply With Quote
Old 08-28-2010, 11:44 AM   #5
Purdy Swoft
Purdy Swoft's Avatar
I agree, but the 0 size cables are usually hard to find. I also use them.
Old 08-28-2010, 11:52 AM   #6
Tinker
Tinker's Avatar
Did the same with my truck 2/0 welding cable from the local welding supply store. Had ends put on for all battery connections, starter and ground. Huge improvement.
The welding cable has a lot more strains of wires.
Old 08-28-2010, 12:56 PM   #7
pdora
pdora's Avatar
Further question from OP
"Had ends put on for all battery connections, starter and ground."
Can this be done by the welding supply people?
Will they cut to any length, even just a few inches?
Old 08-28-2010, 01:10 PM   #8
criswellnk
criswellnk's Avatar
I would go to Rhode Island Wiring Service at riwire.com
You can get 1, 1/0 or 2/0 (my personal choice), they will cut to the length that you need and attach the terminal ends as well. The cable is a modern cable with a cloth loom woven over it so it looks spot-on. I have them make the cables for anyy antique vehicle that I have. Just give them a call and they will be happy to help you out, and the turn around time is fairly quick as well. Also ask for them to send you a catalog.
criswellnk is offline   Reply With Quote
Old 08-28-2010, 01:16 PM   #9
Tinker
Tinker's Avatar
I measured out all the lengths and bought a full length of wire from the welding store. We have a battery supplier here. They supply batteries for cars, boats, forklifts. I gave them all the wire and they cut it and put all the ends on it. Also shrink wrapped the ends. Wasn't the cheapest route, I think it was about $50, but they look and preform very well. Battery ground, battery to solenoid, solenoid to starter, and engine ground.
Old 08-28-2010, 01:17 PM   #10
Tinker
Tinker's Avatar
I think they sell by the foot. I kept the connects as short as I could. A couple were only 6" or less.
Old 08-28-2010, 01:19 PM   #11
Jack '29 Sport Coupe
Jack '29 Sport Coupe's Avatar
Auto Zone carries them in the size and length you need---and zero and one, are just fine. I wouldn't use anything smaller than a size two.
Jack
Cincinnati, Ohio
Jack '29 Sport Coupe is offline   Reply With Quote
Old 08-28-2010, 01:25 PM   #12
Tinker
Tinker's Avatar
Old 08-28-2010, 03:33 PM   #13
pdora
pdora's Avatar
Thanks for all the helpful comments.
I might try the local Batteries Plus and see what they have to offer.
Old 09-02-2010, 10:48 PM   #14
pdora
pdora's Avatar
Batteries Plus had nothing to offer, much to surprise.
Old 09-02-2010, 10:57 PM   #15
Tinker
Tinker's Avatar
No welding stores in your area? Or just go with autozone (retail) cables. Might be the least painless path for what it's worth.
Googled this in Covington Ga, close? Maybe worth a call.
Odyssey Battery Sales
10117 Industrial Drive
Covington Ga. 30015
Tel. (770)787-8311
Fax.(770)787-8313
http://odysseybatterysales.com/cgi-b...-battery-sales
Old 09-02-2010, 11:37 PM   #16
pdora
pdora's Avatar
Yes, is close.
Thanks for the suggestion.
Old 09-03-2010, 05:37 AM   #17
Tom Wesenberg
Tom Wesenberg's Avatar
The starter cables I've used from Bratton's have worked well for me.
Old 09-03-2010, 05:44 AM   #18
pdora
pdora's Avatar
All this started because a previous owner mounted the battery in an oddball manner requiring longer than normal cables. He then proceeded to use skinny wire, probably 4 gauge.
Yesterday I managed to restore the battery to its proper place, so I have ordered traditional Model A cables which should resolve the entire issue.
Thanks for all the help and encouragement.
Old 09-03-2010, 06:19 AM   #19
Bruce Adams
Bruce Adams's Avatar
All the vendors soupply the proper cable and West Marine has 0 gauge cables and connectors if you wish to make your own.
Bruce Adams is offline   Reply With Quote
Old 09-03-2010, 10:04 AM   #20
Purdy Swoft
pdora, Whatever cable that you end up using, I highly recommend adding an extra ground cable, even if it is a smaller size than the main cables. Here is how that I do it. The ground cable connects to the center crossmember, right behind the battery. I used a bouble eyed cable of suficient length and connect one end under the ground cable that connects to the center crossmember and connect the other end under one of the bolts that holds the transmission top in place. Make sure to remove any paint or rust if present where the cables will be connected. It will all be worth your time. The small cables that are used for 12 volt applications will quickly overheat and could be a hazard. Good luck. Purdy Swoft in HOT Alabama.
