Just got a set of new aluminum pistons for my engine rebuild from Brattons. These pistons don't have a slit at all in the skirt. How much clearance do you allow in the cylinder walls for these pistons? Is it the same as the pistons with the slit? There are no dumb questions...right?
Thanks |
Pistons with the slit can be fit a little tighter. Usually the new pistons have a clearance recommendation with them. Off hand I'd think about .0025 to .0035" would be OK, but wait for Dave or Herm to answer.
Location: 40 Mt.Vickery Rd. Southborough,MA 508-460-0733
Correct: on the pistons they do recommend .002-.003" as i contacted them in Taiwan and a few weeks later i received a response.
Ok, another question. The wrist pins can be pushed in with my thumb. It this ok? I thought they were supposed to be a tight fit?
They have snap rings with the set. I have already fitted the connecting rod bushings to the wrist pin. |
You stated it correctly.
They should be easy enough to slide through but not loose enough to fall out. |
