Old 10-18-2013, 03:57 PM   #1
jimcarl
jimcarl's Avatar
Unhappy Timing exercise gone bad
After reading several articles,threads, books on timing, I tackled my 31 SW. Couldn't find the timing wheel dimple by feel, so resorted to visual inspection and successfully positioned it to TDC. Proceeded to adjust cam and rotor to remove as much backlash as possible and felt pretty good about it all. Reassembled everything and tried to start it.
That's when things went south. It cranked a few times, then stopped with a jolt. Starter wouldn't turn at all. Got out to take a look and heard gas pouring from the carb (a Tilly). Removed the carb and there was daylight between the two halves. Tried to turn the engine by hand and it wouldn't budge. So now I am down a carb and can't turn the engine.
Hoping someone will have a great suggestion for releasing the engine and then we will all have a good laugh instead of me spending thousands of dollars on a new engine.
Right?
Much appreciated,
Jim
jimcarl is offline   Reply With Quote
Old 10-18-2013, 04:05 PM   #2
700rpm
700rpm's Avatar
Default Re: Timing exercise gone bad
Try a short phillips screwdriver in the timing pin hole instead of the pin. Sometimes a sharper point can detect the indent on the timing gear. If that doesn't work, remove your front timing cover and enlarge the indent.
Ray Horton, Portland, OR
Old 10-18-2013, 04:12 PM   #3
Ross/Kzoo
Ross/Kzoo's Avatar
Or a center punch.
Ross/Kzoo is offline   Reply With Quote
Old 10-18-2013, 04:17 PM   #4
jkeesey
jkeesey's Avatar
Yup, sounds like your starter got stuck. Rock it in high gear as described and you may have the timing too far advanced.
jkeesey is offline   Reply With Quote
Old 10-18-2013, 04:31 PM   #5
Tom Endy
Tom Endy's Avatar
Whenever you attempt to start a Model A always put the spark advance lever all the way up otherwise the engine can try to fire backwards. When this happens it can jam the starter. This is also how people got broken arms when attempting to crank start the car with the spark lever in the down position.
Tom Endy
Old 10-18-2013, 04:34 PM   #6
rusted
Are you sure you were on the compression stroke when you had TDC? Put your thumb over # 1 spark plug hole and feel for the pressure as the piston comes up. You could be 180 degrees off and that is what caused the starter to lock up.
rusted is offline   Reply With Quote
Old 10-18-2013, 04:44 PM   #7
jimcarl
jimcarl's Avatar
Thanks all, for your quick attention. Rocking it in high gear was the solution - thankfully!
Thanks Tim for being the first to recommend this and to you Jon for confirming.
Tom, I'd seen your spark advance warning in another thread, so believe me, I am listening to that advice!
Good ideas for finding the indent. I'll be trying them right away as I think we all can agree that Tim's quote that "your timing may require further adjustment" is a bit of an understatement!
Jim
Old 10-18-2013, 04:45 PM   #8
jimcarl
jimcarl's Avatar
rusted, I'm guessing you are correct in that assumption. Thanks!
Old 10-18-2013, 05:00 PM   #9
ford3
just a suggestion to any one replacing the timing gear, always deepen and widen the dimple on the gear it will save your sanity when tunning your engine
ford3 is offline   Reply With Quote
Old 10-18-2013, 05:03 PM   #10
jkeesey
jkeesey's Avatar
ford3 I would not do either. Instead if anything sharpen the point on the timing pin. The original dimple is not a wear point but if you make it deeper and wider it can misconstrue your true TDC.
Old 10-18-2013, 05:48 PM   #11
ford3
jkessey, on most repo cam gears you can barley see the dimple let alone feel it, if you just widen and deepen it just a little the timing pin will fall into it with out using some home made or make shift tool, the timimg pin is there for a purpose, use it
Old 10-18-2013, 05:51 PM   #12
ctvpa
ctvpa's Avatar
Les Andrews has a video on you tube on how to time the car. I took my computer to the shop and did it step by step. I hit the pause button, then went to the next step. You need a light socket, 6v light bulb, some wire and 2 alligator clips.
I can idle mine as slow as a hit or miss.
ctvpa is offline   Reply With Quote
Old 10-18-2013, 06:15 PM   #13
kwisor
kwisor's Avatar
hello all
i was timing my car the other day i did find the dimple with out any problem i had to sharpen the tip in the pin but my question is when i did this i for got to take the pin out and started the car would this have caused any damage to timing gear
kevin
1930 model a tudor
1923 model t roadster p/u
kwisor is offline   Reply With Quote
Old 10-18-2013, 06:19 PM   #14
ford3
probably not, when the high side of the dimple came up it would have just pushed the timing pin out of the way
Old 10-18-2013, 06:28 PM   #15
kwisor
kwisor's Avatar
thank you ford3
kevin
Old 10-18-2013, 06:48 PM   #16
Tom Endy
Tom Endy's Avatar
I take it a step further. I paint the dimple with red fingernail polish. When ever I re-set the timing I crank the engine around until the rotor points to the right headlight. Then using a flashlight and a dental mirror I step in front of the bumper put my knee on the crank handle and ease the timing gear the rest of the way around until the red dot is looking at me in the mirror.
Tom Endy
Old 10-18-2013, 07:31 PM   #17
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Jim, to "KNOW" if your timing is correct, with warm engine & idle speed & idle mixture adjusted well.
1- Spark up=a smooth & rythmical, TADA-TADA-TADA-TADA.
2- Spark 1/2 way down=a faster smooth idle.
3- Spark full down=an even faster, but somewhat "rolling" idle.
If you have all these, timing is PERFECT. Bill W.
"THE ASSISTANT GURU OF STUFF"
