Old 09-22-2013, 10:01 AM   #1
46fordnut
46fordnut's Avatar
Default shut off
i took my 46 out just around the block.. ran really well...drove for maybe half hour pulled in driveway then sputtered and shut down....set my choke then pumped gas pedal like crazy ..it started up . small hesitating for a few seconds then drove fine into garage ... changed condenser after this happened i was thinking this might be it ...but then might be low fuel...rebuilt carb newer fuel pump...
if rust were money i would be a billionaire!!
46fordnut is offline   Reply With Quote
Old 09-22-2013, 10:56 AM   #2
ford38v8
ford38v8's Avatar
Default Re: shut off
Rather than condenser, I'd bet on vapor lock. Pulling into driveway, almost no airflow through the engine compartment, bingo.
Wait a minute! A half hour to drive around the block? What, in reverse?
Alan
ford38v8 is online now   Reply With Quote
Old 09-22-2013, 04:44 PM   #3
46fordnut
46fordnut's Avatar
no just time ref to give an idea how long the engine ran for...i was just taking at easy just got it back out after two year not running. seems not to like leaving the garage.
