Old 08-16-2010, 11:56 PM   #1
callcoy
Default Gordon Smith Compressor
We found a Smith compressor in a collapsed garage made from a Model A chassis. Most likely a a do-it yourself type conversion, with the frame shortened, transmission removed and the rear end moved forward, forming a trailer. The condition of the engine is unknown and the history is also unknown. The owner would like to sell it, what do you think would be a fair price for the as is considering the unknowns.
Steve - Santa Rosa
callcoy is offline   Reply With Quote
Old 08-17-2010, 12:17 AM   #2
'29wagon
Default Re: Gordon Smith Compressor
more unknowns considering the lack of pictures, put some up to see how quick it goes.
'29wagon is offline   Reply With Quote
Old 08-17-2010, 07:53 AM   #3
Frank Miller
Frank Miller's Avatar
Not worth a whole lot more than a questionable may or may not run Model a motor. They are nice when they are running if you have a use for them. Do not pay more than $100. If you plan to make it usable make sure all needed parts are there. Governor, pilot valve and head. You may want to have whatever is there for a tank inspected before you put pressure to it.
Frank Miller is offline   Reply With Quote
Old 08-17-2010, 08:45 AM   #4
Kurt in NJ
Kurt in NJ's Avatar
Start with scrap value, add if complete (unloader,idle back, pressure regulator, governor, special carb limkage), add more if not siezed and hand cranking will make it pump air ( mine will).
The valves in the compressor section are just flat sections of spring, if they break the head gets chewed up quick ---if you can turn it over and it pumps there is a good chance that the valve strips are not damaged.
Old 08-17-2010, 09:45 AM   #5
Rowdy
The last one I sold on e-bay only brought $125. The 30-31 Model A cowl and tank was worth more than that. For that reason I have not listed my other one and not sure I will. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
