My 49 F1 started overheating. Pulled the thermostats & tested. Made sure they were installed correct. What am I missing?
Is it loosing water? I would start by warming the engine to make sure thermostats are open, fill radiator to the top, remove the water pump belt(s), run the engine and look for bubbles in the radiator neck. Bubbles will indicate leakage from the combustion chamber.
Leave the thermos out
Thanks, will try. It holds water pretty good. Heats up to stall after driving a block
What is the condition of the rest of your cooling system? when did you change coolant last , when was the last time the radiator was serviced?
"Came too close to dying to stop living now!" |
Lonnie |
welcome to the 'Barn....got pics??....hope your problem gets solved with minimum fuss.....Mike
#8 | |
![]() Quote:
Before I pulled it apart I'd at least try torquing the heads, always best to do the cheap and easy stuff first, IMHO. |
So, the thermostats have been in and out so many times. what the proper direction. Thermo is stamped "Radiator" direction. Toward radiator or toward block
The side with the spring mechanism is what senses the water temp. It needs to be to on the "hot" side or towards the block.
As stated, spring towards block sitting in goose neck like this.
Isn't it ironic that your having a heating problem and your name is "Wasabi" Mike?.... Mark
P.S. I'm not making light of your issue and I do hope you get it solved before any damage is done.
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver…RIP |
#13 |
Like I said leave them outttttttttttttt until you find out what's wrong with it .Ted
#14 | |
![]() Quote:
Just my thoughts based on your stalling comment. |
#15 |
So, it has a 4# radiator cap. After a driving a block, it heats up enough to spew water out of the cap thus getting coil & disttributor wet, hence engine stalling
#16 |
The cap should not leak it should spew out the over flow pipe .replace the cap and check that the overflow pipe is clear , It could be a head gasket ,but do the other first ,Ted
#17 |
was talking to someone today about a Flathead overheating. The owner pickup a newly rebuilt engine and it overheated before he got home.
Turns out he did not clean out the radiator when the engine was rebuilt.
3 pedals, 3 gears, no valve-covers.. Now THAT is a hot rod ![]() https://www.youtube.com/watch?v=ZmwwB34vxJE |
#18 | |
![]() Quote:
If it don't get over 210 it's not hot enough to blow out through a 4 lb pressure cap. If it's not hot and water comes out it's a compression leak or the cap isn't working. It could be that it no longer holds 4 lbs or the most likely case the rubber at the bottom of the cap is NOT touching the washer like seat down in the bottom of the filler neck. For some reason almost all 4 lb caps don't seat. When you put the cap on line up the locking tabs and you should be able to feel the spring pressure on the bottom seat before the underside of the top of the cap hits the top of the filler neck. I have to cut a red rubber washer about 1/8" thick and put it down on the bottom seat after cleaning it good. Fill the coolant up into the filler neck it will run cooler with more coolant. G.M.
www.fordcollector.com |
