Hey guys, Iv got a set of these wheels, there 21s.
Iv never seen any like these, theres no beed around the edge. Any clue what they are ? thanks |
That rib thing runs up to the lug nut hole instead of between them. i cannot find a decent picture of a 1927 wheel that might have been different.
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
Apparently, there were some 21" s produced without the bead edge. They had the rim edge same as 1930'31 19"'s.
A couple of FBers have posted pics of them . If you have a set, I would use them, as a talking point. The so called AR wheel had a bead edge rim like all 21's, but the hub area was slightly different shaped to fit the early type drums, the rears without the separate brake band. Last edited by Tudortomnz; 03-27-2013 at 01:57 AM. |
Could they be the early 28 or (AR)
Wanted: Simmons Super Power Head ![]() Craig Likon 1931 150B |
I recently toured Mike's Affordable Model A parts in Georgia. Mike has one of these wheels mounted on the wall by his front door. He knows some of the history behind it.
#6 | |
I am enclosing a picture of a 26/27 wheel for comparison. I too have encountered a couple of 21's like you show and I have always suspected they were someone's aftermarket wheel. Maybe not.??. ![]() |
I saw several of these 21" wheels without the bead edge in Brazil. Has anyone from Argentina seen them there too?
These wheels actually belong to a old friend of mine, and he did import 4 model A,s from Argentina some years ago, now I'm thinking this is where these wheels came from.
Hmmm all very interesting. Thanks for the pic Brent
I've seen wheels like that from Argentina !! Usually the spokes are Oxy -Acetelyne welded at the rim Check the spokes before you use them !!!!!!
Johm Cochran |
very interesting...I saw a set of Western Auto rims about ten or fifteen years ago but cannot remember if they had such a configuration.
if those wheels are manufactured in Argentina, for replacement, the company is PROTO, were built between the years 40 and 70
"Los hombres cobardes ven la muerte muchas veces, los hombres valientes solo una" "Siempre hay que tratar de ser el mejor, pero nunca creerse el mejor". J.M. FANGIO |
#13 |
Four posts down, the pickup from Argentina has three of these wheels.
#14 |
these are my wheels, 2 originals made in usa, and 3 made in Argentina
