Does anyone have any experience or literature on tuning the Miller Carburetor that was sometimes sold with the Miller overhead conversion Sold by Harry Miller inc.? I have a miller carb on my Miller overhead and would like to get it tuned up. I have found no info on the net. Any help would be appreciated.
Rod |
I've never seen any literature on them, that doesn't mean there is none. Those carbs were meant for track use and I think you will find them less than ideal for street use if that is your intention? If I recall right there is only one adjustment, for idle. The jets on the spray bar should be OK as-is unless it ran alcohol and you want to run gasoline. I've seen guys spend a lot of time and energy trying to run Riley carbs on the street, and they were never really right.
#3 | |
![]() Quote:
The carb I have has the vacuum piston with an adjustment on the spring. I assume that by putting less tension on the spring, I will lean up the mixture. Does that make sense? I also have a mixture screw that does not seem to do anything. I also have a idle stop screw that sets the idle stop on the rotary venturi. Any help is appreciated. I am trying to locate a copy of Mark Dee's book to borrow. I have found one for sale on Amazon, but it is very pricey.
#5 | |
![]() Quote:
![]() I think I may have read this some where-- Didn't Miller sell his carby companies/or the right for someone else to build his carbys, a couple of times. Then he just started up again?? There is a cut-away drawing with part names, of a Type H carby from the 1920s in the "Miller" book by G. Borgeson. HTH Manuel in Oz |
Good info Bill, I've never seen a Miller carb with the vacuum system, but then you are much older than I am :-)
#10 | |
![]() Quote:
I have a Miller Automatic Carburetor, pat. dates 1917 and '18, Mfg. Harry A. Miller, L.A. CA. It is brass, updraft, throat about 1-3/8" (they're supposed to go by 1/4" increments), and has a float bowl that can be rotated around the body to adapt to various installations. It does NOT have the rotary jet-bar throttle that typified so many of Millers racing carbs, but is very simple. I don't doubt it was for racing, as much like a Hilborn injection system, is not set up for idle or low-velocity use. I have always suspected that it was on a banger set up, poss even modified T. I bought it for $3 at a junk shop in about 1972.
I really admire Harry Miller, a typically erratic genius but one that makes me proud of the USA, and wouldn't part with it for mucho dinero. I'll bet it wasn't easy to tune or run unless at racing speeds, either! I've never seen another, not even an illustration. My info came from the Addendum/Erratum booklet from Mark Dees big Miller book, as he forgot to include any notice of it in the original edition. Oh well.... |
