Old 03-26-2013, 01:03 PM   #1
wrndln
Default Brake pedal question
I have two brake pedals shown in the picture below. One has a grease zerk like I have seen before (press in). The other one (beadblasted) has a strange threaded place I assume is for a grease zerk. The hole appears to be about 1/4" in diameter, which is smaller than all the threaded places for zerks I have seen. Is this pedal for a later model A like a 30 or 31? I have all 28/29 vehicles and that is what I need the pedal for.
Rusty Nelson
Old 03-26-2013, 02:30 PM   #2
160B
160B's Avatar
Default Re: Brake pedal question
Based on page 7-2 of the Restoration Guidelines and Judging Standards the pedal on the left is "Typical pedal with lubricator fitting used from May 1930 to end of production" and it looks like the one on the right is "Typical pedal used from Nov 1928 through May 1930 without lubricator fitting" The size and location of the hole indicates it was an owner modification to add a lubricating point.
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 03-26-2013, 02:42 PM   #3
Joe K
Joe K's Avatar
He did exactly what I did on my March 1929 truck. Drill a hole and use a push in grease zerk. Except this zerk is now missing. Come to think of it the zerks don't hold in place real well.
I did drill mine about mid-way along the bushing - much like the later version.
Joe K
Shudda kept the horse.
Joe K is online now   Reply With Quote
