Old 06-28-2018, 02:26 PM   #1
deuce5wndw
deuce5wndw's Avatar
Default Help Id Jahns pistons
Hello guys, I have a set of Jahns pistons and printed on the end of the box is 8-985 RP, FORD, and 3 15/16 std. I have searched on the internet but no luck with that number. I don't know of a Ford engine with a 3 15/16 bore! I looked in a Motors repair manual and the only engine I could find that had that size bore is a 1955 Lincoln 341.Thanks for your help, Dale.
deuce5wndw is offline   Reply With Quote
Old 06-28-2018, 05:47 PM   #2
scicala
scicala's Avatar
Default Re: Help Id Jahns pistons
Here is a link to an EBAY auction for and old 1956 Jahns Piston catalog. One of the photos shows 985 H is for a Ford or Merc Y-Block V8 high compression with a dome. Only trouble is that the biggest Y-Block V8 (312) has a 3.80" bore. 3 15/16" is 3.9375". Way too big of an overbore for a 312. Plus your box says Std. bore. Maybe 985 RP is a forged piston for a Lincoln Y-Block 317, 341 or 368 ? I know they made forged pistons too.
Sal
https://www.ebay.com/itm/VTG-1956-JA...sAAOSw53NY9k0z
scicala is offline   Reply With Quote
Old 06-28-2018, 08:24 PM   #3
deuce5wndw
deuce5wndw's Avatar
Thank you scicala, Mine are 985rp where those are 985h. I measured them and they do measure 3.9375. They appear to be cast pistons from looking at the inside. Thanks again, Dale.
Old 06-28-2018, 08:50 PM   #4
miker98038
miker98038's Avatar
If it looks like they might be MEL, try over at y blocks forever. There’s several MEL guys there.
miker98038 is offline   Reply With Quote
Old 06-28-2018, 09:01 PM   #5
scicala
scicala's Avatar
All MEL V8's had bores well over 4" so they can't be for a MEL. I agree they do look like cast pistons and no dome like the 312 Y Block 985 H piston. Since the box says Ford, they have a good chance of being 1955 Lincoln 341 pistons. Like you said, it's the only Ford V8 with that standard bore.
Sal
Old 06-29-2018, 07:32 AM   #6
deuce5wndw
deuce5wndw's Avatar
They are parts I have for sale and just wanted to represent them correctly. Thank you for your help, Dale.
Old 06-29-2018, 05:20 PM   #7
KULTULZ
KULTULZ's Avatar
Post Re: Help Id Jahns pistons
Shown is an ILL of an early MEL combustion chamber showing unique MEL piston top-
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 06-29-2018, 05:44 PM   #8
scicala
scicala's Avatar
Correct. MEL's were like 348 and 409 Chevy's, in that the head was flat with no real combustion chamber in the head.
Sal
Old 06-29-2018, 06:22 PM   #9
KULTULZ
KULTULZ's Avatar
Sal
You mean the CHEB was like the MEL don't you?
The 1963 LINC MEL 4V re-design did have combustion chambers in the cylinder heads.
Old 06-29-2018, 10:40 PM   #10
scicala
scicala's Avatar
The 348 Chevy and MEL came out at the same time (about 1958), so they were like each other at the same time.
I didn't realize the '63 Lincoln MEL had combustion chambers. Still learning after all these years.
Sal
Old 06-30-2018, 02:13 AM   #11
KULTULZ
KULTULZ's Avatar
THE 410 MEL was to be introduced in the 57 MERC but foundry problems delayed the intro.
It went to the 58 EDSEL (intro JUL 57).
EDIT-
Below is a 64 430 CYL HEAD and PISTON-
Old 06-24-2022, 01:39 PM   #12
B-ster
I don't suppose these pistons are still available. I am looking for 341 pistons
B-ster is offline   Reply With Quote
Old 06-24-2022, 03:58 PM   #13
55blacktie
deuce 5, thank you for doing your homework before selling the pistons. I frequently find parts on ebay, the sellers of which have no idea what they have.
55blacktie is offline   Reply With Quote
Old 06-26-2022, 07:15 AM   #14
KULTULZ
KULTULZ's Avatar
Question Re: Help Id Jahns pistons
Are you the gentleman with the 1953 LINC? Your machinist has no lead on replacement pistons? He hasn't machined anything yet has he?
File Type: jpg ENGINE - PISTONS-RING SETS - 1952-54 LINC.jpg (20.9 KB, 62 views)
Old 06-26-2022, 11:01 AM   #15
B-ster
It's a 54 but yes
Old 06-26-2022, 01:31 PM   #16
B-ster
What's MEL?
Old 06-26-2022, 02:29 PM   #17
dmsfrr
dmsfrr's Avatar
Mercury Edsel Lincoln
A Ford family of engines or parts used in those vehicles.
Old 06-26-2022, 06:57 PM   #18
B-ster
I meant yes, I'm the guy. But no. Mechanic hasn't found any yet. Saw some 368 pistons new for sale but not sure if the 317 will bore out safely to that size
Old 06-26-2022, 07:19 PM   #19
Dobie Gillis
Dobie Gillis's Avatar
These guys say they have 341 pistons:
https://www.performancenowdirect.com...9-302-317-341/
Often wrong but never in doubt.
Dobie Gillis is offline   Reply With Quote
Old 06-26-2022, 07:31 PM   #20
B-ster
I have an inquiry to them. Tried Kanter too, they don't have them. Eggy also not
