Old 10-14-2015, 05:17 AM   #1
hootF1
Cool holley 390 question
what is the required fuel pressure for the 390 on a flathead?
hootF1 is offline   Reply With Quote
Old 10-14-2015, 05:45 AM   #2
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Default Re: holley 390 question
I would say 3# would be alright if you not running the salt flats. Walt
Old 10-14-2015, 06:21 AM   #3
51 MERC-CT
51 MERC-CT's Avatar
If you mean what are the fuel pressure limitations of the carb. (doesn't make any difference what engine it's on )
This is Holley specs.
"Recommended fuel pressure should be set at 7-1/2 psi maximum, 5 psi minimum. Fuel pressures above 7-1/2 psi can create severe fuel control problems and are not recommended."
It will be fine with flathead fuel pump.
Old 10-14-2015, 07:28 AM   #4
scooder
Can a regular flathead pump deliver the required minimum 5 psi?
The late Merc pump for use with the Holley 885 and tea pot should be good to go, as these carbs used a higher pressure. But the early ones?
Martin.
scooder is offline   Reply With Quote
Old 10-14-2015, 07:44 AM   #5
51 MERC-CT
51 MERC-CT's Avatar
Martin.
It does not need 5 psi. to operate well on any flathead single or double pumper fuel pump in normal driving conditions.
Old 10-14-2015, 09:31 AM   #6
RandyZ
I've been running mine for years on the original fuel pump. No problems.
RandyZ is offline   Reply With Quote
Old 10-14-2015, 10:37 AM   #7
WestCoast
the 390 was originally designed for the bigger bore v/8's,those required more fuel thus more fuel pressure, the stock ford 239 v/8 will not use enough fuel to make it necessay to run more than the 2# to 3# fuel pressure
WestCoast is offline   Reply With Quote
Old 10-14-2015, 11:09 AM   #8
JWL
I am with RandyZ--I ran one for several years with my stock Flathead pump. No problems.
JWL is offline   Reply With Quote
Old 10-14-2015, 01:26 PM   #9
scooder
Thanks for the info chaps, it was the "minimum" pressure bit that made me question the suitability of the stock pre Merc pumps. If you guys say it works good, that's ok by me. I'll put there "minimum pressure" filed under baloney, and pay it no mind.
Again, thanks.
Martin.
Old 10-14-2015, 03:45 PM   #10
41LjH
41LjH's Avatar
8BA modified engine.
my 390 ran 3-5 lbs with a Mr. Gasket electric pump. No regulator installed and the original fuel pump removed..
3 pedals, 3 gears, no valve-covers..
Now THAT is a hot rod !!
https://www.youtube.com/watch?v=ZmwwB34vxJE
41LjH is offline   Reply With Quote
