09-29-2015, 03:14 PM | #1 |
Replacement for 4 blade steel fan on 36???
Need to know if there is a replacement fan with more blades for the 15" steel four blade generator end mounted fan. I have a 36 engine that the steel fan was removed and electric fan was installed ( shoe horned between distributor and radiator) I removed the electric fan to work on distributor. I want to install a fan that will work better than the 4 blade steel. Thought I started reading about this on Fordbarn last week but cannot find thread if it exist. Any info or up grade information appreciated, Bruce
09-29-2015, 03:37 PM | #2 |
Re: Replacement for 4 blade steel fan on 36???
there was a 6 blade fan that was a option in 36. I am also on the hunt for one. Just missed one on ebay. They were used on trucks most of the time. Good luck finding one
Ford |
09-29-2015, 05:16 PM | #3 |
I found a 6 blade fan 2 years ago. (Might sell for the right offer) Since I rebuilt my Carb. and it seems to run better and cooler and I have heard that the 6 blade is noisy so its hanging on my garage wall along with a chromed 4 blade fan I picked up along the way and have been reluctant to install be cause I show my 36 Cabriolet as mostly stock.
09-29-2015, 05:54 PM | #4 |
Looking for authenticity or a fan?? Plastic??
Paul in CT |
09-29-2015, 06:05 PM | #5 |
I am looking for an original
Ford |
09-29-2015, 06:59 PM | #6 |
09-29-2015, 07:06 PM | #7 | |
Bill |
09-29-2015, 07:33 PM | #8 |
I had a 6 blade fan many years ago that looked like the stock 36 Ford 6 blade fan with bolted blades to hub and fit on the generator pulley. ONE MAJOR PROBLEM the fan blade pitch was exact opposite of a Ford 4 blade fan. Not sure what it was from but it would be a pusher fan. Maybe some engine application that wanted to keep dirt out of the radiator. Mystery to me, but be sure of the pitch angle directionbefore you buy one.
09-29-2015, 07:39 PM | #9 |
Thanks Gary, Bulldozer's have reverse pusher fans, Grain harvester's also. Model A suppliers make a 6 blade fan ( plastic I think ). Asked Joe at Joe's Antique and he did know of one and recommended I ask on Fordbarn.
09-29-2015, 09:26 PM | #10 |
Too much noise Bruce,you wont like it!!!!!!!!!
DON P |
09-29-2015, 10:27 PM | #11 | |
Charlie Stephens |
09-29-2015, 10:39 PM | #12 |
What size pulley do you have on the generator--if you have the large diameter one changing to a smaller diameter will increase fan speed
09-30-2015, 10:27 AM | #13 |
I bought a 6 blade fan for my 53 from speedway had it bored out to fit the hub, not very noisey works great, the ends are turned out, maybe that willl helpthe noise. I am also using ac.
09-30-2015, 03:06 PM | #14 |
I put a plastic puller fan on my radiator and did away with the belt mount. An electric fuel pump, and a set of mechanical 1 1/2" oil pressure, and temp gauges in my glove box.No more overheating in traffic or parades. I cut the fan off when I'm moving at a reasonable clip. No more overheat, or vapor lock issues. HOORAY!
Yeah, it's not "original" but I want to drive it, not look at it broke down on the roadside. Especially with the wife aboard. |
09-30-2015, 07:51 PM | #15 |
There's a 6 blade fan on ebay. Listed today around noon. Located in
N Dakota. $65.00 buy it now price. Al |
09-30-2015, 08:15 PM | #16 |
Johndee138, mine had a puller fan, had to remove to get coil/distributor off to clean and tune up, how did you attach to radiator. The one I removed had little plastic type nails with plastic washers. I had to remove one upper radiator hose to work fan out. Thanks for information, Bruce
09-30-2015, 08:39 PM | #17 |
Henry I looked at that fan it's not a 36 the mount is to deep
Ford |
