07-25-2022, 03:50 PM | #1 |
Modified T-5 Imput Shaft TO Bearing Sleeve
City:
Lago Vista
State:
TX
Price:
300.00
Model A 4 Banger to Mustang T-5 Transmission Input shaft & TOB Sleeve for the Vintage Precision Bellhousing
If you want a T-5 Mustang transmission behind you banger 4 cylinder this is a necessary item to modify the transmission to not have to cut the crossmember. The links below are the modified DWG of this and the bell housing from Vintage Precision. Any transmission shop can install this shortened input and modified TO bearing sleeve. The TO bearing is a Flathead V8 version for this sleeve. https://vintageprecision.com/artwork...n_retainer.pdf https://vintageprecision.com/product...ngs/index.html |
08-04-2022, 04:00 PM | #2 |
Re: Modified T-5 Imput Shaft TO Bearing Sleeve
