09-18-2016, 11:15 AM | #1 |
Steering Box Leak
Yesterday I adjusted the sector shaft end play on the 7-tooth steering box in my ’28 roadster. When I started I had about 4-1/2 inches of play in the steering wheel. Now I have about a quarter inch of play. As I was working on it I slowly and frequently added 250-wt Texaco Thurban steering gear grease which I have been using in several of my cars for many years. The steering feels real smooth and the car is easy to steer as I have the Teflon buttons in the tie rod and pitman arm ends and a shortened pitman arm.
I took the car for a 10 mile spin and then had a beer. This morning I saw a puddle of grease on my driveway. I’m not sure this was due to overfilling or to the adjustment or both. Suggestions will be appreciated Thanks, Robert |
09-18-2016, 11:43 AM | #2 |
Re: Steering Box Leak
One positive way to check for leaks in any container such as a gear box is to remove the top plug to visually inspect the level of lubricant.
Model As have an 80+ year long history of lubricant leaks from different sources. |
09-18-2016, 11:52 AM | #3 |
Are you talking grease as you state or oil ? Wayne
09-18-2016, 12:30 PM | #4 |
This doesn't work well in this case. The thick grease takes time to flow down the worm so it appears full each time you top it off. I know it leaks because there was fresh grease on my concrete driveway.
09-18-2016, 12:41 PM | #5 |
FWIW:
Under "Search" there are numerous recommendations not to use grease for Model A steering gear lubricant ....... but ....... like all other unlimited Model A opinions and recommendations ...... they are like planets in the universe scattered as far out as infinity ........ most in life just grab a specific planetary opinion to their liking and run with it. |
09-18-2016, 01:28 PM | #6 |
the cork light switch rod seal should be replaced with the kind with a tube the quick seal for the sector is the plate/O ring between the frame and gear---but greasing the fitting could help the cover has a gasket, I have seen them shrunk into the housing leaving a big gap |
09-18-2016, 01:51 PM | #7 |
Do you have this tube installed?
http://parts.modelastore.com/show_Product.asp?ID=3299 I see you have a 28 this might not fit ... Last edited by Benson; 09-18-2016 at 02:13 PM. |
09-18-2016, 02:49 PM | #8 |
PennRite steering box lube=NO Leakie. FWIW
Paul in CT |
09-18-2016, 03:01 PM | #9 |
I use John Deere "corn head grease" Its a thick oil or a thin grease. It's a good grease
for the steering gear. JB
Connoisseur of Rust |
09-18-2016, 03:17 PM | #10 |
The label on the 5-gallon pail says SAE 250 and is a mineral oil and is used for steering boxes. I’m sorry I called it grease. The steering box in my ’34 roadster was leaking and I solved that issue with this stuff some 5 or 10 years ago.
I think I’ll take a chance and order/install an oil retainer with tube like the one on page 24 of the 2016 Brattons catalog. This part is for ‘28s and ‘29s and hopefully it will fit. My ’28 roadster has a mid-September 1928 serial number. Thanks for your help, Robert |
09-18-2016, 04:51 PM | #11 |
Your photo, (34 Roadster ), looks just great ..... appears they must be rare.
09-18-2016, 05:04 PM | #12 | |
I replaced the felt seal around the lighting rod with a rubber washer designed to fit the spindle of a water tap. It made the steering a bit stiff for the first few miles but everything is now OK. My set up is the same as Robert from Texas with Teflon tie rod/ drag link ends and short pitman arm. I did replace the worm and sector as well as the various bushes last winter. The play went from 4 1/2 to 1/4 inch. No leaks as yet using 600W oil. |
12-09-2016, 10:47 PM | #13 |
Hey Robert, thats a real sweet lookin roadster you have there. Dutie
12-10-2016, 09:23 AM | #14 |
Thanks for the complements on my '34 roadster. I have 6 pre-war Fords and this is the one I like and drive the most. Also 1934 is the year I was born.
On the '28 roadster I solved the leak problem by replacing the horn rod using a standard felt seal as the tube type seal didn't fit. The old horn rod was badly butchered where the c-clip goes and I think it's looseing of the compressed felt seal was the cause of the leak. Thanks again for everyone's help and interest, Robert |
12-10-2016, 09:43 AM | #15 |
Problem solved, next ! Wayne
12-10-2016, 10:59 AM | #16 |
Just a note: Minervas' steering box was apparently rebuilt, nicely, except for FINAL adjustments.
I found it was pumped 2/3 full of CLEAR grease, from the lower fitting, but the grease was "channeling"---Topped it off with Valvoline Multi-Vis Synthetic Gear oil. In 2 weeks of driving, it gradually got EASIER & EASIER to steer & DIDN'T LEAK. Bill W.
