I need a 6 volt miniature bayonet #51 bulb for my Signal Stat 900 directional light system. Does anyone know a bricks and mortar store that sells these bulbs?
Thanks! Dave See #13 for update. Last edited by Pilotdave; 05-03-2016 at 04:09 PM. |
I think maybe Snyder's??
Paul |
try napa? they have alot of oddball parts, maybe an electrical supply store? a real one not menards or lamp depo or something i mean an industrial place like fastenal, or grainger.
sometimes old old hardware stores still have a variety of bulbs around. i know you said physical store but amazon has a 10 pack for $8... http://www.amazon.com/10-PACK-Eiko-M.../dp/B003JW0F2E macs for buck a piece http://www.macsautoparts.com/ford_tr...t-bulb-51.html
Do a google search lots show up "#51 bulb 6volt"
http://www.cmwauto.com/MainMenu/Lamp...lamp_bulbs.htm |
Around my area we have a store called Battery Plus. They're a chain store. They carry a larg assortment of light bulbs. Check to see if you have one in your area. And give them a try.
The NAPA part number is LMP51
Thanks for all the replies! I'll start with NAPA in the morning.
The back story: after trying a variety of things to get the indicator lights in the Signal Stat to light up, I finally took it apart and found........no bulb! Dave |
#9 | |
![]() Quote:
#10 | |
![]() Quote:
How/why does a bulb know which side is ground? I have never tried to put hot to ground and vice versa but I would THINK a simple bulb should work. No? |
Regular bulbs don't care about polarity, but LED needs the current to flow the correct direction.
#13 |
Order the bulb through my local NAPA shop. Installed and working! Thanks for the assist.
Dave |
#14 |
what did they take outa your pocketbook for the bulb? curious...
#15 |
I had to buy a box of ten...about $8.50 for the box, so $0.85 for one bulb.
#16 |
#17 |
In the UK, try http://www.norbsa02.freeuk.com/goffystandardbulbs.htm
