07-13-2018, 06:41 PM | #1 |
Rh and Lh steering column tubes
Is there a difference between the RH and LH steering column outer tube (the one with the throttle and accelerator levers)? I have reviewed the book by Les Pearson and cannot find the answer. I know the gas lever has no ball on the end, but cannot see another difference.
07-13-2018, 07:25 PM | #2 |
Re: Rh and Lh steering column tubes
No difference in the tube , spark & throttle rods are different ,in that the holes through the levers are at a different angle , too LHD , hope that helps,
07-13-2018, 08:18 PM | #3 |
Thanks Derek, I knew you would have the answer.
07-13-2018, 08:23 PM | #4 |
