09-01-2023, 07:21 PM | #1 |
Holly 94 Pump Return Spring
Hey everyone, took apart my Holly 94 (the later 1940s Model 59), and I noticed that the pump does not return upwards. Before, they had a spring mounted to the accelerator arm ball joint going to the generator. Yikes! After rebuilding the carb, I noticed there's no return spring to push the pump back up. I've seen two schematics... one that shows a spring of some sort in with the Pump Operating Rod (don't know how, there's no room in that shaft), and then another with a spring under the pump that pushes it back up. Which is correct, and where can I find one or the other?
1940 Ford DeLuxe Fordor Sedan 1944 GPW Jeep |
09-01-2023, 10:04 PM | #2 |
Re: Holly 94 Pump Return Spring
Use 37 and 96.
09-01-2023, 10:10 PM | #3 |
Okay. So what's the spring on the rod? I have the spring that's on the actual pump/plunger. But that's the only spring I have in that system. Any idea where I might find that particular pump spring? I see some for sale and specialty places, but they don't look like they're for this particular Holly unless it doesn't really matter.
09-02-2023, 02:42 AM | #4 |
And, is this what I need? Seems to be for 50CC.
https://www.oreillyauto.com/detail/c...g/hly0/2010910
09-02-2023, 05:34 AM | #5 |
Contact Charlie NY, 716-662-9159. Charlie not only has the parts, he also has the knowledge.
09-02-2023, 06:35 AM | #6 |
09-02-2023, 07:59 AM | #7 |
Like Terry, OH, I have never experienced a carburetor with a spring under the accelerator pump.
Parts 37 and 38 in the second image are what you need. |
09-02-2023, 10:41 AM | #8 | |
09-02-2023, 03:54 PM | #9 |
09-03-2023, 08:39 AM | #10 |
This is from a later carb, but the concept is the same. Sometimes a picture, is better than a drawing. Hope it helps.
09-03-2023, 04:47 PM | #11 |
Greetings Warbird,
There is NO spring on the outside of the "Accelerating Pump Operating Rod" #9531 in the upper illustration. The "Accelerating Pump Link" # 9526 connects #9531 to the "Throttle Shaft Linkage" # 9581. Your pictures looked familier. In my first post I asked for info about my installed carb, which comes from a '55, sans choke. (I didn't know about it) In an old candy tin, covered in rust and dirt was the old carb, completely disassembled. I decided to put it back together. I got most of it correct, but left out the throttle rod because the throttle plates are so corroded they don't go in the slots, same with the choke plate. So I never connected the pump link. When I saw your diagram and the photos, I went and got the carb and the link and rod were still in the bottom of the can. Note: #9531 has a Spring Loaded Ball inside the Hole! That is why there is a Notch in the Shaft of #9526. A clip does not go in the notch I'll try to attach photos. JP |
09-04-2023, 08:28 AM | #12 |
09-05-2023, 02:27 AM | #13 | |||||
Exactly, so what is pushing the rod back up (with the plunger) after you press the accelerator? Quote:
And yes, I have the ball and clip to hold it in place!
09-06-2023, 10:23 AM | #14 |
"But what I don't understand is how that rod with the plunger returns, or goes back up, after the accelerator is pressed."
It doesn't go back, up until you let off the accelerator. First picture is with the the accelerator all the way up. The second picture is the the accelerator partially pushed down and the pump having bottomed out . The third picture is the accelerator pushed all the way to the floor When you let off the accelerator, it returns to the first picture Hope this helps. Last edited by Merc Cruzer; 09-06-2023 at 12:30 PM. |
