Old 12-05-2013, 10:08 PM   #1
Art Bjornestad
Art Bjornestad's Avatar
Default V8 water pump adapter
Does anyone know who makes or sells the part that lets you run a 32-34 V8 pump on a model A?
Art Bjornestad is offline   Reply With Quote
Old 12-05-2013, 10:26 PM   #2
quickchange
quickchange's Avatar
Default Re: V8 water pump adapter
Have one spare in New Zealand, If that's a help, Derek,
quickchange is offline   Reply With Quote
Old 12-05-2013, 10:27 PM   #3
denis4x4
denis4x4's Avatar
Bert's in Denver 800/321-1931
denis4x4 is offline   Reply With Quote
Old 12-06-2013, 03:42 AM   #4
Mike V. Florida
Mike V. Florida's Avatar
Mikes Afordable is another place A8501ADP
Old 12-06-2013, 04:08 PM   #5
just plain bill
just plain bill's Avatar
Antique Auto in Rosemead might be a little closer
just plain bill is offline   Reply With Quote
Old 12-07-2013, 12:17 AM   #6
Brendan
Brendan's Avatar
I had one on my A. the V8 pump cant handle a fan, it is not designed to handle the rotating mass. I went back to Model A pump. why do you won't a V8 pump?
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 12-07-2013, 08:34 AM   #7
Lembomw
Lembomw's Avatar
Brendan, can you provide more information on the problems you had with the V8 water pump you had on your Model A. What do you mean by it cant handle a fan?? I am looking into installing an adapter and a V8 water pump on my engine.
Thanks, Mark
Lembomw is offline   Reply With Quote
Old 12-07-2013, 10:23 AM   #8
Brendan
Brendan's Avatar
a original V8 water pump has a bushing in it, a model a pump has a bearing in it.
when I got my car it had a V8 pump on it. the guy I got the car from said that the pump had about 50 miles on it. I put about 50 more miles on it and then it was toast!
the bushing went out and it had about 1/4 end play in it and was leaking very bad.
I decided to get a V8 pump from Dennis Carpenter. I had to change the pulley to except the fan, the Carpenter pump had a bigger shaft then the old pump. I had to do this to run a fan. I have a Dennis Cling serpentine belt set up on my car, with his 5 blade fan. so after the Carpenter pump did not work I got a Sniders leak less pump . it works great.
Old 12-08-2013, 08:38 AM   #9
Lembomw
Lembomw's Avatar
Thank you Brendan. Good info.
Mark
