I guess some will say this is the wrong site to ask this. but i would bet s everal here have upgraded there A . i installed a Weber two barrel with a cast iron exhaust and the header gets so hot it will boil the gas and the hood handle is very hot. my question is has any one else had this problem and how did you fix it ?. It vapor locks also.
Go to a motorcycle store and purchase a wrap kit for pipes. You wet it prior to install, and then wrap it overlapping each round. This will help with immediate heat transfer.
The second side is it sounds like the fuel mixture is lean. Lean mixtures and/or retarded ignition timing will cause the engine manifolds to overheat. Remember that the Weber 32/36 carburetor was O.E. on engines like the Pinto & Vega where the cubic inch range was under 150. Even the V6 Pinto engine only had around 170 cubic inches. A stock bore Model-A has cubic inches of just over 200. Bottom line is the carburetor is likely too small for the application, ....especially with one that has siamesed ports that feed back-to-back cylinders. |
