Old 03-10-2012, 11:02 AM   #1
jrelliott
jrelliott's Avatar
Default Fuel Gauge not reading correctly
The cork on my fuel gauge must have absorbed gas as does not read correctly. Showed empty but when tried filling gas, pump kept shutting off and saw gas in the gauge window. Have heard about changing the cork float to a tillitson carb float but cannot see how to do that. If anyone has made this change could you send me the instructions.
Old 03-10-2012, 11:33 AM   #2
V4F
V4F's Avatar
Default Re: Fuel Gauge not reading correctly
it takes a long time to saturate a float . i buy good new ones .......
V4f
V4F is offline   Reply With Quote
Old 03-10-2012, 11:37 AM   #3
700rpm
700rpm's Avatar
The problem is in your tank, not your carburetor. Get a new gas gauge float and gasket set from your Model A parts supplier. They come with instructions on how to replace the float.
Ray Horton, Portland, OR
Old 03-10-2012, 12:39 PM   #4
FL&WVMIKE
FL&WVMIKE's Avatar
jrelliott ......................
I think you have figured out your problem.
The original "A" Model floats were coated in shellac, which was gas proof. The alcohol in today's gas, disolves this shellac.
MIKE
FL&WVMIKE is offline   Reply With Quote
Old 03-10-2012, 02:11 PM   #5
msmaron
msmaron's Avatar
Just remember to DRAIN The tank below the gauge or....well you get the picture!
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 03-10-2012, 03:41 PM   #6
1931 flamingo
1931 flamingo's Avatar
DISCONNECT THE BATTERY BEFORE YOU DO ANYTHING!!!
Paul in CT
Old 03-10-2012, 03:56 PM   #7
al's28/33
al's28/33's Avatar
Disconnect the battery, make sure the gas level is below your gauge (use a long stick to see about how much you have left if the gauge is giving you false readings). Remove the instrument panel, loosen the clamp holding the speedo cable on the inside firewall to give a little slack. Remove the gauge with the special tools. You can either get a whole new gauge unit or replace the cork with a new neoprene float or a brass float from Mikes Affordable Parts.
Search old posts you will find a wealth of information on all the options.
Old 03-12-2012, 10:50 AM   #8
jrelliott
jrelliott's Avatar
Thanks to all who respnded.
Old 03-12-2012, 11:13 AM   #9
MikeK
MikeK's Avatar
When I was in Dallas in '08 for the world meet my gauge window started leaking badly. The tank metal contact surface for the gasket was never very good, and I had just changed the gasket(s) before I left Chicago. I borrowed the gauge tools from the repair tent and went at it. A good Samaritan smelled what I was doing and handed me some blue Hylomar in a brush can. I used it on the gaskets and the seal is perfect. If you haven't done the job yet, try Hylomar.
While you're at it, if it's not a fine-points car you may want to change the "F" at the top to a "B" (bankrupt)
MikeK is offline   Reply With Quote
Old 03-12-2012, 11:28 AM   #10
Tom Endy
Tom Endy's Avatar
You can use a brass float from a Tilotson carburetor in place of a cork or neoprene float. They are tubular shaped and easily fit through the boss in the tank during installation. It is a simple matter of soldering the brass float onto the end of the wand.
Tom Endy
