Old 08-30-2011, 11:06 AM   #1
nemw001
Unhappy 1937 No start
Hello all - I am currently working on a 1937 Ford - it came into my shop as a crank-no start - it had no spark - I sent the distributor which was original out to be refurbished at VanPelts, had a condenser and rotor installed so I would not have any issues once I put it back on. I have spark now BUT still wont start - it backfires through carburetor. I checked spark intensity and it is a nice bue/whiteish - and I ohmed checked wires and they are like maybe (4) ohms resistance. I checked the timing gear/chain for looseness by barring engine clockwise marking a spot on cover then bringing it back in opposite direction, did this several times, and there appears to be no more than 1/2" play. I then took the caps off and inspected the halves and the contacts and they appear fine. This is quite a simple set up but right about now after hours of checking it out I am baffled. Any suggestions???? Thanks.
nemw001 is offline   Reply With Quote
