Old 05-26-2025, 06:39 PM   #1
psimet
psimet's Avatar
Default Gaskets
How do you all install your gaskets? Dry? With silicone? With grease?
Transmission to clutch housing
Transmission tower to transmission
Flywheel housing to clutch housing
Valve cover on engine (engine builder says grease on that one)
Timing covers on engine
I used silicone on the u-joint and steering box gaskets but just looking to see what people do generally.
psimet is offline   Reply With Quote
Old 05-26-2025, 07:15 PM   #2
Y-Blockhead
Y-Blockhead's Avatar
Default Re: Gaskets
Not a fan of silicone, I use mostly just grease. I do use "The Right Stuff" in certain situations sparingly.
Old 05-26-2025, 08:18 PM   #3
Gary WA
Gary WA's Avatar
Default Re: Gaskets
I use Indian Shellac from auto parts supplier.
www.whidbeymodelaclub.com
Gary WA is online now   Reply With Quote
Old 05-26-2025, 08:51 PM   #4
JayJay
Default Re: Gaskets
On most paper and cork gaskets I put a very thin coating of Hylomar Blue on each side of the gasket. Hylomar Blue is a non-hardening silicone based gasket sealer. I don’t use it anywhere it might contact gasoline, for example carb to manifold (I use copper gaskets there anyhow, but there are paper gaskets available).
Flywheel housing to clutch housing there should be minimal oil anyhow, so dry.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 05-26-2025, 10:13 PM   #5
Richard Knight
Default Re: Gaskets
I find the "right stuff" is the right stuff for a lot of gaskets!
Richard Knight is offline   Reply With Quote
Old 05-26-2025, 11:27 PM   #6
J Franklin
J Franklin's Avatar
Default Re: Gaskets
I usually install dry. On my T were covers need to come off often I use silicone on one side, and grease on the other, so the gasket may be reused many times.
Old 05-27-2025, 05:25 AM   #7
nkaminar
nkaminar's Avatar
Default Re: Gaskets
I recently discovered Right Stuff gasket sealer and it solved a persistent oil leaking problem. I used it on both sides of a paper gasket. Where gasoline is involved I use Permatex Form-A-Gasket #2. They have many sealants and other products on their website: https://www.permatex.com/. They make some sealants that are designed for easy disassembly. I have not tried those.
Old 05-27-2025, 07:07 AM   #8
Bob-A
Bob-A's Avatar
Smile Re: Gaskets
I use a permatex liquid gasket sealer that I thin some with denatured alcohol. A trick I learned from an old Harley mechanic. In/exhaust gaskets
I use copper coat.
Bob-A
"Skirts are for Women not Car Fenders"
Bob-A is offline   Reply With Quote
Old 05-27-2025, 02:42 PM   #9
ThirstyThirty
ThirstyThirty's Avatar
Default Re: Gaskets
I have always said, "engine building, engine repairs... part tech, part craftsmanship... and artwork, too!"
interesting to read these numerous options, choices to seal gaskets. shellack, a new one for me!
"My Model A... work never ends, only the day ends!"
ThirstyThirty is offline   Reply With Quote
Old 05-27-2025, 06:36 PM   #10
Big hammer
Default Re: Gaskets
I just used Permatex high tack sealer on the cork oil pan gasket to keep it stuck to the pan and a bit of grease on the engine side. I want the gasket to stay with the covers and not stick to the engine side, it’s much easier to clean old gaskets off of parts removed than scraping off the engine !
get a bigger hammer tap done
Old 05-27-2025, 08:34 PM   #11
David in San Antonio
David in San Antonio's Avatar
Default Re: Gaskets
Fun fact: Shellac is made from the shells of beetles. Try working that into a conversation in the next week or so.
Late ‘30 Deluxe "Wretched Roadster"
Alamo A’s Club
David in San Antonio is offline   Reply With Quote
Old 05-28-2025, 09:05 AM   #12
JayJay
Default Re: Gaskets
Also - shellac is best dissolved in denatured alcohol, not the usual petroleum-based solvents we typically use. Available at hardware stores, but don’t drink it, it has been spiked with methanol, which turns to formaldehyde in your eyeballs. Not a good thing.
JayJay
Old 05-28-2025, 10:54 PM   #13
ThirstyThirty
Default Re: Gaskets
Old 05-28-2025, 09:42 AM   #14
Wick
Wick's Avatar
Default Re: Gaskets
I've used oil on cork and paper gaskets for 50 years, My grandpa (1902) insisted on doing it this way so you could reuse a gasket. A thick paper bag or roofing felt made a good gasket also.
Wick is offline   Reply With Quote
Old 05-29-2025, 07:29 AM   #15
old31
Default Re: Gaskets
Ok, so what i got out of reading this thread.
1: shellac comes from the shells of beetles.
Your a bunch of beetle killers. The beatles where the best thing to invade this country.
2: your eyeballs will turn to formaldehyde.
And by the way for years I have replaced many paper gaskets with the right stuff. I spray copper head gaskets with copper coat.
old31 is offline   Reply With Quote
Old 05-29-2025, 10:43 AM   #16
Ruth
Default Re: Gaskets
Actually shellac is made from a resin secreted by the female lac bug. shellac - lac.
Ruth
Old 05-29-2025, 12:06 PM   #17
TomInCologne
TomInCologne's Avatar
Default Re: Gaskets
which is the origin of the word ‚lacquer‘ or ‚Lack‘ in german. From the hindu word for those beetles, actually lice.
TomInCologne is offline   Reply With Quote
Old 05-29-2025, 04:30 PM   #18
Y-Blockhead
Default Re: Gaskets
Dang! We be learnin' some shit today!!
Old 05-29-2025, 05:58 PM   #19
ModelA29
ModelA29's Avatar
Default Re: Gaskets
Glue cork gasket to cover and grease other side when installing - reusable several times that way. I'd probably work with paper gaskets too. I wouldn't use silicone - too often I've opened up engines and seen gobs of silicone floating around from using too much. Those could easily plug up or restrict some of the splash oil passages.
Hint glue the gasket to the removable part that's easiest work on the bench with.
ModelA29 is offline   Reply With Quote
Old 05-30-2025, 07:14 AM   #20
nkaminar
nkaminar's Avatar
Default Re: Gaskets
Permitex makes gasket sealers that are designed for easy disassembly and cleanup, see promotional video at: https://youtu.be/Bd7YV6QHVaU.
Modern engines use gasket sealers that are applied using a robot. The amount and location is controlled precisely. No gasket is used, just the sealer.
