I have a '47 59AB. I was working on the engine, on a stand, and I tipped the damned thing over onto the concrete floor. Broke off three cylinder head studs below the block surface and have started the process of drilling out the broken stud ends and installing Time-Serts in the holes to accept the new head studs. Two of the hole drillings went great but on the last one, I drilled too deep and entered the coolant chamber.
![]() ![]() ![]() In the bad hole, if I finish installing the Time-Sert and apply a liberal amount of JB Weld to the new stud before installing, will this seal the hole and prevent a coolant leak in that hole? These broken studs are located on the lower rear bank below the battery. Any suggestions would be greatly appreciated. Thank you, Phil |
#2 | |
![]() Quote:
I'd reconsider using JB Weld on the stud. There are better sealants. Maybe to fill the extra drill hole, but not the stud.
I would avoid using anything permanent, just use Permatex Aviation or #2. Something non-setting.
Your grandson might want to work on it one day |
#5 | |
![]() Quote:
This is wonderful news. I guess what I'm seeing in the first two drilled holes, are just the bottoms of the old studs and not the bottoms of the holes. (They ain't no stinkin' bottoms in the holes!) I will certainly use the correct sealant on the new studs. Thank you ![]() ![]() ![]() |
69a: "I would avoid using anything permanent, just use Permatex Aviation or #2. Something non-setting. Your grandson might want to work on it one day." I have a lot of experience using both products. I still use JB often. I do like it. ![]() The Aviation Permatex will be a better choice to seal stud threads to block threads where water is or can be present. To use the JB product, some very special efforts would need to be made to ensure proper cleanliness, particularly down in the block's threads. Hence, Aviation Permatex is a much better choice and it is much more forgiving, too. Good Luck with your engine project. and don't think you are the only guy who has ever had an engine on the stand... tip over!! ![]() It is always an event sure to ruin one's day!! ![]() the move went without a hitch! ![]()
"My Model A... work never ends, only the day ends!" |
I am going through the same misrable problem studs must have a high carbon content to snap instead of bend I will fab a floor stand with a plate on the same plane as the block and use a mag.drill fingers crossed.
#8 | |
![]() Quote:
Again, GOOD LUCK!!! |
#9 | |
![]() Quote:
Drill an 1/8” hole through broken off studs. An Oxy/Acetylene torch is needed ( and for sure some experience using oxy /acetylene set) use Cutting torch set how you would cut 1/4” plate simply blow the broken stud out. The threads in block will not even get red. After blowing out all remains of stud simply run a tread chaser in to clean up. Been using this process 50 years. |
Lock and stitch company has a line of “full torque” inserts and they have blind hole inserts for such a problem.
