Old 12-02-2024, 02:39 PM   #1
art ebeling
art ebeling's Avatar
Default 41 steering wheel
Will a 1940 car deluxe steering wheel with 3/4" spline fit a 1941 Pickup?
art ebeling is offline   Reply With Quote
Old 12-02-2024, 03:37 PM   #2
19Fordy
19Fordy's Avatar
Default Re: 41 steering wheel
I am 99.9% sure the 40 wheel will fit the 41 pickup. Read this entire post, especially #23 and 24.
https://www.fordbarn.com/forum/showt...4967&showall=1
Old 12-02-2024, 04:50 PM   #3
Kube
Kube's Avatar
I've never witnessed a '40 steering wheel with a spline.
A true '40 passenger car wheel will fit a '41 pickup truck.
Old 12-02-2024, 05:31 PM   #4
art ebeling
I asked that because the Dennis Carpenter ad say 3/4 spline.
Old 12-02-2024, 05:48 PM   #5
Kube
Kube's Avatar
Hmmmm...
As you no doubt know, the steering wheel has a taper fit.
Perhaps the "kid" that wrote the description for Carpenter is simply a kid and has no clue.
Just now looked at the Carpenter ad. That isn't a spline. It'll fit your '41 pickup just fine
Old 12-02-2024, 06:42 PM   #6
19Fordy
19Fordy's Avatar
"THANK YOU" , Kube for ascertaining correct info.
Old 12-02-2024, 07:16 PM   #7
art ebeling
Thanks Kube, That is the information I needed. This is not my truck but belongs to a friend who wanted to order today to get a ten percent Cyber Monday discount. He asked me and I told him we would get an answer on the Barn. Art
Old 12-02-2024, 08:02 PM   #8
fordyford
fordyford's Avatar
The confusion is in not knowing the difference between a key and a spline.
fordyford is offline   Reply With Quote
Old 12-02-2024, 09:49 PM   #9
cas3
The confusion could be that the aftermarket does make wheels with a spline for the street rod folks. I've not seen the wheel in question, but if Kube says its a go then its a done deal
Old 12-03-2024, 06:14 AM   #10
art ebeling
I knew that the steering wheel on my 36 is keyed and also the 47 I have. Some suppliers described the 41 pickup steering wheel as fits "Big Hub" but Dennis Carpenter is the only one that has them in stock and the 3/4 spline description didn't make sense. I agree that Kube gave me the correct information, Art
Old 12-03-2024, 10:19 AM   #11
Kube
Kube's Avatar
The ad on Carpenter's site clearly depicts a tapered / keyed hub.
Hopefully that's what they ship.
Drake made wheels at one time, and they were tapered / keyed. Not quite the correct depth of taper but a good attempt anyway.
Old 12-03-2024, 11:08 AM   #12
TJ
TJ's Avatar
There are wheels out there with splines, but they fit GM columns. If you have a stock column you need a wheel that is tapered with a key way. If you call Carpenter you need to ask questions. On e-Bay there is a new 17" '40 wheel with taper and key fit for $300. There are also two new 16" wheels that also have the taper and key for $320, but 16 " is not stock. All these wheels are for the "40 deluxe and the pickup uses a "40 standard wheel.
