My '31 Victoria has the stock, two blade fan. I am aware of all the inherent potential tragedy, regarding these fans, and their propensity to come apart and turn into flying shrapnel while the engine is running. Good (new), two blade fans, seem hard to find. Is there a way to "bullet-proof" this original fan, much the same way as you can "bullet-proof" a Columbia overdrive, and make this safe to use?
It would be nice to keep this original fan. Thank you, Phil |
I would say no to the modifications and just wait (or find) an aluminum replacement.
The Restorer has an article that addresses this.
47 - I believe Snyders actually makes the aluminum two-blade fan. Tam's says they are out of stock until October, other vendors simply say "out of stock". If you want one you might contact your favorite vendor and see if you can get on a waiting list. I did that a couple of years ago when those fans were similarly out of stock. As soon as Bert's got an order in they shipped me two per my standing request.
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! |
Take it off your car. It’s a tragedy waiting to happen.
Order the aluminum two blade and wait for delivery. I have had an original fail. It’s not pretty. Your engine compartment could take a real beating or worse. Please do not take a chance. Enjoy. |
the later ones don’t seem to crack at the hub—- I have seen plastic blades break and go though hoods too |
Fully Agree! - Horton
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. ![]() |
OK!!!!! Out with the old, in with the new. A new aluminum two blade.
Thanks for your responses. |
It's going to fail. It's a crap shoot when. If you want to run it because it's a fine point car at least pull it off annually and magnaflux or dye check it for cracks.
There is a very good reason why the ford dealerships replace the 2 bladed vans with the 4 bladed fans anytime they have the opportunity it was definitely a safety issue even back then!!!
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
Hello, true , those old 2 blades were a problem even then, recalled back in 1970,s with my 1st Model A , “old timers “ telling me stores of broken fan blades. The only problem I had with the new blades is sometimes you have to remove a bit of water pump “snout “ as the new pulley area is thicker being cast . Also currently on A I am restoring, the hood side panel has a dent from inside out , probably from broken fan at one time.
Had a guy lose his radiator and hood on one of our club meets. Flat bed here we come.
#13 |
I have a friend that wanted me to change his water pump. He said everything else was perfect, so dont spend any more money! The car was truly a+ restoration when it was done with this fan. When I took off the fan off this is what i found.
How long do you think he had? 1 fan revolution, 50-100? |
#14 |
delete
#15 |
The original two-bladed fans are fine, as long as you don't run your engine.
#16 |
#17 |
Why not replace the fan with a moder safe on and enter the original fan as part of the tool kit? Safety first.
#18 |
In today's world considering they're almost 100 years old the original ford 2 bladed fans should be considered for display purposes only!!!
#19 |
This is where original fan blades belong.
#20 | |
![]() Quote:
I don't like reducing the nose of the pump because it loses strength right where I put a ball bearing as part of my conversion. Are you listening, Snyders?
I sometimes wonder what happened to the people who asked me for directions. Even at my age, I still like to look at a young, attractive woman but I can't really remember why. |
