Old 08-19-2024, 06:59 PM   #1
Wolfe.brennan
Default Flathead swap questions
Good evening,
I'm debating on keeping the flathead in my 35', as local builders and parts are an issue in my area. Seeing as this will be a daily, I would like to find an easy-to-use, or as close as possible drop in. Preferably, I would like to not cut the firewall. Any suggestions?
Wolfe.brennan is offline   Reply With Quote
Old 08-19-2024, 07:16 PM   #2
47topless
47topless's Avatar
Default Re: Flathead swap questions
Ford 302 CI / 140 HP
47topless is offline   Reply With Quote
Old 08-19-2024, 09:13 PM   #3
Wolfe.brennan
Is this a minimal modification or will cutting be needed?
Old 08-19-2024, 10:00 PM   #4
51504bat
51504bat's Avatar
As much as I hate to say it a sbc would be the easiest swap. Using an adapter to your existing trans makes it even easier. Pretty sure you'd have to cut the firewall for a sbf but not positive. Other options are a Pinto 4 banger or a Chevy Iron Duke or an earlier Chevy 4 banger out of a Chevy II.
Old 08-19-2024, 10:25 PM   #5
Wolfe.brennan
Interesting! Never seen a four banger in one. I have a small block chevy that could work in a pinch..
Old 08-19-2024, 07:35 PM   #6
Wolfe.brennan
I'm interested, as I found this in cylinder 6
Old 08-19-2024, 10:00 PM   #7
Kurt in NJ
Kurt in NJ's Avatar
That cylinder 6 has a replaceable tin sleeve that can be changed in the car
Old 08-19-2024, 10:24 PM   #8
Wolfe.brennan
I'd be interested in salvaging it,as it is the only one with a major issue. Due to my inexperienced with this particular engine,it's rather daunting.
Old 08-24-2024, 09:13 AM   #9
glennpm
glennpm's Avatar
Kurt, what tooling is required to do this?
I would think this the best option and keeps it as a flathead. The chassis and other components will like the flathead better :-)
Glenn
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat's Notes
Techno-Source-for-the-1932-thru-1953-Flathead-Ford
Old 08-19-2024, 10:35 PM   #10
itslow
itslow's Avatar
Are you wanting to keep it Flathead but asking whether to use the 59A or 8BA variants, or asking which alternative non-Flathead would be the easiest swap?
If the former, then the 59A will be slightly easier due to the belt spacing.
If the latter, then it will be a (gasp!) Chevy small block. Not only from the fitment standpoint, but the parts availability standpoint as well.
Mike
Wanted:
- '32-34 Open Cab Pickup (RPU) parts and documents/articles/info
- ARDUN parts
itslow is offline   Reply With Quote
Old 08-19-2024, 10:38 PM   #11
Wolfe.brennan
I'd prefer to keep what I have, but I am open to alternatives. It's not going to be a hotrod,or race car,but a daily,with potential for long trips every weekend.
Old 08-20-2024, 04:24 AM   #12
Ggmac
Where do you live ? I have a couple of 37 lb motors that are good running motors . I’m starting to down size and need the room .
The tin sleeve motors are pretty easy to change the liner in , as long as you can locate the liner . There are many manuals , books etc that can walk you through the process.
Ford shop manual is the first Id suggest.
The sbc is the easiest to install , I’ve done 1 recently only because I wanted AC and a good cruiser at highway speeds . That’ll lead to the next problem going on the highway , brakes . Fords brades are adequate for the speeds normal with the flathead, but at 60 mph + a self energized setup or disc is preferable.
Both the sbc and brake upgrades are doable and common .
Sorry for rambling.
Old 08-20-2024, 09:01 AM   #13
Zeke3
Zeke3's Avatar
I put a small block Ford in my 1937 back in the mid sixties and had to modify the firewall and front of the oil pan sump to get it in. It didn’t fit all that well. Look at my avatar and you can see where I have repaired the damage that I had done to fit the sbf.
Zeke3 is offline   Reply With Quote
Old 08-20-2024, 10:30 PM   #14
Wolfe.brennan
In O'Fallon,Illinois. I'd be interested, as I am learning how to completely rebuild and recondition these engines, in time. It's an excellent hobby.
Old 08-20-2024, 09:10 AM   #15
TJ
TJ's Avatar
To put in the SBC you have to pull the existing motor. Once it is out why not try to find a machine shop and have them replace the sleeve?
Old 08-20-2024, 09:12 AM   #16
Wolfe.brennan
True, but I'm at the point where, if it costs too much, I cannot justify its existence.
Old 08-20-2024, 01:51 PM   #17
Ggmac
It’ll cost you about $400 to swap in a sbc . Plus the cost of the sbc . Exhaust manifolds , clutch , flywheel , pilot bearing , hurst style mtr mount , conversion bell housing . The $400 dollar estimate is finding good used bellhousing and hurst mount .
Old 08-20-2024, 05:21 PM   #18
Kurt in NJ
Kurt in NJ's Avatar
Those sleeves were intended to be installed in the chassis, they came pre honed.
Old 08-21-2024, 02:33 AM   #19
deuce lover
deuce lover's Avatar
The Hurst mount won't work . The 35-36 front crossmember does not drop down enough.The mount will interfere with the spring U bolts. Been there and done that.I should have kept the Flathead.
Another thing is ,what engine is in your '35 ? 21 stud babbitt main bearings?
Old 08-21-2024, 06:36 AM   #20
Wolfe.brennan
It's a 38 engine, insert bearings. I've seen other mounts work, but the flathead probably isn't going back in for a long time.
