Old 07-29-2024, 04:38 PM   #1
NCSUDucker
NCSUDucker's Avatar
Default Seat removal 39 1 ton
Quick question. Have upholstery on order as well as all wiring harnesses. Obviously the seat will need to come out to reupholster and I imagine it will make life easier for rewiring. Any tips would be greatly appreciated.
NCSUDucker is offline   Reply With Quote
Old 07-29-2024, 06:52 PM   #2
paul2748
paul2748's Avatar
Default Re: Seat removal 39 1 ton
Not that familiar with your truck, but typically there are four bolts holding the seat to the floor, two on each side, for a bench seat. Look under the truck for the nuts (or bolts). They may be bolted through the frame rail or the floor panel.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 07-29-2024, 06:55 PM   #3
NCSUDucker
NCSUDucker's Avatar
Thanks, the 1 ton truck has the gas tank under the seat so I wasn't sure. It's at the shop right now so I haven't had time to crawl around. In just glancing, the seat back is where I'm not sure.
Old 07-29-2024, 06:56 PM   #4
ActionYobbo
ActionYobbo's Avatar
Seat back has bars that go up into the brace under the window. There is 2 locating studs on the front of the seat base (gas tank)
Step 1 lift the front of the seat base 1”
Step2 slide seat base forward until sear back untabs from the window brace
Step3 pull top of seat back forward while moving the seat base back (fold the seat)
Step 4 remove it out the passengers side
What upholstery did you get? I still have to do my seat and have not found anything made to fit
I am building a 1939 1 ton express
ActionYobbo is offline   Reply With Quote
Old 07-29-2024, 07:12 PM   #5
NCSUDucker
NCSUDucker's Avatar
Thanks Yobbo. I found a lady who does upholstery for classics and had good reviews on Etsy. I went with the Stock Mama but there are a lot of nice looking options. If she doesn't have it listed, she can still do it.
https://www.etsy.com/listing/1190963...ef=share_v4_lx
Old 07-29-2024, 07:25 PM   #6
GB SISSON
GB SISSON's Avatar
NCSU, I replied to your PM but it seems it didn't send. I sold my 38 tonner 25 years ago and it's been mostly newer ford since then. If it's like the jailbar trucks, which have a similar mounting atop the tank, there are 2 straps, one each side between the seat base and the tank's surrounding 'skirt'. These are at the rear of the seat 's cushion. At the front edge of the seat base it sits on a couple of steel pegs, shaped like bullets that are attached to the tank's skirt frame. Looking at the front edge of the seat cushion from the underside there are two steel strips, maybe 1 1/4" x 3", each having 3 holes for seat's fore and aft adjustment. In other words, the bullet pegs locate the seat in your choice of three positions. You have to lift the front of the seat off the bullets and slide it forward or back. The seat back, if like the jailbar trucks has a sort of hinge on both sides at the top. Simply pull the hinge pins and lift the seat back out. I hope this helps.
Old 07-29-2024, 07:32 PM   #7
NCSUDucker
NCSUDucker's Avatar
Thanks and no worries GB... I'm bad to miss private messages since there is no notification or popup. Just figured that was the case on your end as you have been a good source of info on all of the ton truck questions I've had so far.
Old 07-30-2024, 01:41 AM   #8
ford38v8
ford38v8's Avatar
Just a word about seats of this era... I know that pickup seats are a breed of their own, but seats in general are considerably more comfortable than modern car seats. My own '38 was such a pleasure to drive, the seats so comfortable, my wife and I felt refreshed after a 600 mile drive rather than how tiring a similar drive in a modern car would be.
All this to say, don't even think about ditching the coil springs for sponge rubber, and if your upholstery shop tells you sponge rubber is better, run don't walk out the nearest exit.
Alan
Old 07-30-2024, 10:14 AM   #9
NCSUDucker
NCSUDucker's Avatar
No worries, keeping the springs! Can't imagine anything else wit the stiffness of the 1 ton truck
