Old 07-14-2021, 09:08 PM   #1
Steve in Denver
Steve in Denver's Avatar
Default Electric Windshield Wiper Motor Needed
I have a ’36 5 window with dual wiper blades on it. The car is 12 volt and not judged. I had the vacuum wiper motor rebuild. It works great til I put the wiper blades on. I checked the vacuum 15 inches. I put RainX on the windows. I know it works great for everyone else, but I could not tell the difference between where I put it on and where I didn’t, and I could hardly see through the drops.
I tried the little electric motor from Drake, $65. It says right on it, “Not for Dual Wipers” and it has a VERY tiny motor. There should be a way to substitute a bigger motor for it that will adapt to the spiral drive.
There has to be some workable substitute besides a string. Anyone figured out a solution? I have looked at the 12v used for the CJ5 Jeep, I would have to cut a hole in the windshield hinge cover. Not completely opposed to that but wanted to see what others have done before I do that.
Yes, I know, Don’t Drive in the Rain.
Steve in Denver is offline   Reply With Quote
Old 07-14-2021, 09:39 PM   #2
Pat's Ride
Pat's Ride's Avatar
Default Re: Electric Windshield Wiper Motor Needed
Going to follow this one. I also need to improve mine on my 38 and would like to see how you resolve the issue.
Pat
Pat's Ride is offline   Reply With Quote
Old 07-14-2021, 10:04 PM   #3
Brian
Brian's Avatar
With my 35, [with dual wipers] I went to a local wrecking yard and bought a rear windscreen wiper motor out of a small Jap hatchback [I 'think' it was a Ford Laser]. Thing is, they sweep through 120 degrees, and have a shallow profile to fit within the constraints of the rear hatch, so fit in behind the header. I did have to open the hole for the wiper tower a wee bit, but now I have good wipers! Go check out your local wrecking yard.
There is some outfit over your country called 'mighty wiper'...dunno about them. Here in the colonies we tend to be creative. lol
Old 07-14-2021, 10:13 PM   #4
fordor41
fordor41's Avatar
Check with aftermarket wiper manuf. One makes a remote motor, like mounted behind the pass. side kick panel, that uses a cable to drive the wipers. Newport eng.?
fordor41 is offline   Reply With Quote
Old 07-14-2021, 10:33 PM   #5
Steve in Denver
Brian, do you have any pictures? Everything I see is huge.
Old 07-15-2021, 12:04 AM   #6
Brian
Brian's Avatar
Sorry Steve, no I have no photos. I did this conversion years ago and it's tucked up hidden by the header. Looking at your photo, sort of jogs my memory that perhaps I shortened up the tower? As I stated earlier, I remember I had to open up the dia of the hole in the roof a tad. Have you investigated the 'mighty wiper'?
Old 07-15-2021, 07:00 AM   #7
Steve in Denver
Brian,
Yes, I have the Not So "mighty wiper". That is the 2nd, 3rd and 4th photos above. I have been looking at the inner net to see if there is a larger motor that I can adapt to the mighty wiper base.
Old 07-15-2021, 07:47 AM   #8
barnfind
Some of the Brit sports cars use a remote mounted wiper motor with cable to the wiper shaft(s) - here's a link to parts diagram:
[URL="/https://mossmotors.com/wipers-wiper-motors"]
I bought a MGB setup off eBay but never got around to installing.
You put the motor in driver kick panel or under the dash and run the drive cable up to the header panel.
barnfind is offline   Reply With Quote
Old 07-15-2021, 08:13 AM   #9
Steve in Denver
I know Moss Motors/XKs Unlimited pretty good from my Jaguar days. Problem with any kind of cable drive is, there is no room. In the '36, all the room there is, is above the windshield, about 2 inches deep, 6 inches wide.
I hope to roam the junk yards this weekend and look for something with a hatch back that has a wiper motor.
Thanks for the thought. Someone has to have solved this problem before now. I can't be the only one with a weak wiper motor.
Old 07-15-2021, 09:10 AM   #10
325w
Mighty wiper works good at slow speeds on my 32 coupe. 60 miles an hour and you have basically nothing.
325w is offline   Reply With Quote
Old 07-15-2021, 11:24 AM   #11
Kruzn40
Kruzn40's Avatar
Newport Engineering makes excellent, easy to install electric wiper motors for old cars. Try them. They may have what you need.
Kruzn40 is offline   Reply With Quote
Old 07-15-2021, 12:00 PM   #12
51woodie
51woodie's Avatar
Steve How much spring tension is there on your wiper arms? The reason I ask, is that a previous owner installed a set of wiper arms and blades on my '46 Coupe, that were not original style. The spring tension was too much for the wiper motor to overcome. I changed to stock arms and blades, and the wipers work reasonably well.
51woodie is offline   Reply With Quote
Old 07-15-2021, 04:55 PM   #13
mfirth
You may want to check a marine supply store. Boat wipers ahve various sweeps.
mfirth is offline   Reply With Quote
Old 07-15-2021, 05:05 PM   #14
51504bat
51504bat's Avatar
Newport Engineering makes one for a '36 Ford. Not cheap but if its anything like the one I have in my '54 Ranch Wagon you'll be very happy with it.
New Port Engineering | 1935-36 Ford Car (newportwipers.com)
The latest and greatest from New Port Engineering is the 1935-36 Ford Clean Wipe Wiper System. This system is a replacement for the original small vacuum wiper motor. The system comes complete with a heavy duty 2-speed motor, linkage and transmissions, Polished Stainless Steel wiper arms and blades and a drill jig fixture to enlarge the original driver’s side hole and locate and drill the passenger side hole. This kit utilizes New Port Engineering’s time tested designs and is designed to give the most sweep and still look great. 12 volt wiring is required.
Old 07-15-2021, 06:31 PM   #15
Ken Henry
Ken Henry's Avatar
Newport wiper motor works great on my 51 pass car
Ken Henry is offline   Reply With Quote
Old 07-15-2021, 07:11 PM   #16
Steve in Denver
Thanks, I will look into it.
Old 07-15-2021, 07:43 PM   #17
Gene F
Gene F's Avatar
I have a 1936 Plymouth streetrod. When I bought it...2 switches for 2 motors. I thought that was weird, but it works just fine. You use your wipers what 2% of the time.....
Old 05-22-2024, 09:35 AM   #18
barnfind
Anyone got a installed pic of the Newport Dual wiper setup for a 35/36 Ford?
From the inside before any upholstery or panels are installed.
Old 05-22-2024, 01:58 PM   #19
325w
Speciality power makes a cable driven dual unit. Have seen them on tri chevys. On the early Ford the motor unit would need to be on the right up high behind the glove box.
Old 05-23-2024, 07:59 AM   #20
pistonbroke
Steve, if your vacuum wipers are rebuilt correctly they should not even need to be turned up to full or they would beat themselves to death. Check you system something is amiss. You should have thick wall 1/4" vacuum hose(the thin junk they sell at most stores will collapse and reduce volume) or steel tubing. If your using the original steel tubing it may have rust inside it. You may also have too much pressure on the blades. There is a tool for measuring the pressure on the glass out there if you like. You should have just enough to keep the blades on the glass at highway speeds. You car and my 36 have the same vacuum motor and mine pushed snow until the wiper was the size of a paper towel spool with ice. Tim
