Old 01-25-2024, 02:02 PM   #1
henryford30
Default Overhauled steering gear is Binding Help.....
Hello specialists
I have overhauled the steering gear on my 30 Coupe.
The steering worm, the 2 tooth steering upper race, the steering sector and all bearings were replaced.
I strictly followed the adjustment instructions and made the adjustments step by step. The steering worked perfectly on the workbench.
But when I installed the steering column and put the load of the Model A on the wheels, I could only turn the steering wheel with a metallic creaking noise.
I then tried to optimize the settings (all 4 options) in the installed state, which unfortunately did not lead to success.
As soon as I take the weight off the front wheels, the steering works perfectly without sluggishness and noise (binding).
The steering column is not braced or installed crooked and the 2-tooth sector gear has no contact with the hole in the frame where the shaft goes through.
What else could I try now, I have spent a lot of money and even more time and unfortunately the result is not acceptable.
Thank you very much for your help !!!
Greetings from cold Munich Germany
henryford30 is offline   Reply With Quote
