Old 12-06-2023, 11:46 AM   #1
bgalla
Default fuel supply problem??
This is about my 31 A. All stock, unmodified. It is in my metal building and not my driver right now. I do start it up and run it around the block every 4-6 weeks, just to keep things working. Even with this things varnish up and require removing the carburetor cleaning it etc.
This time after cleaning it (also a new needle valve) it starts right up runs fine for 5-10 seconds, then seems to run out of gas and dies. I let it sit for a minute or two and the same thing happens. Starts right up then dies in a short period of time. Removed the carb, cleaned it all well, needle valve works with a blow or suck upright and over. Good fuel free flow from the line. The float level has not changed. Puzzles me! Any suggestions? thanks Bruce
bgalla is offline   Reply With Quote
