What is the best way to hold the battery down? I noticed, on the clamp that goes all around top of battery, the negative terminal clamp crosses over the top of the hold down clamp very close. I am concerned that there is potential for this terminal clamp to come in contact with the hold down clamp and short out. Is this a concern?
Bob Bidonde posted a picture of a battery clamp he made that works very well. I can't locate the post. I'm sure Bob will chime in.
The Master Cylinder Enjoying life at the beach in SoCal... |
I was also concerned about the frame being so close to the battery post. I used a disc grinder and sanded some of the frame for clearance and then tapped up the frame. The battery is now locked down securely.
This is the hold down I made, 12 Volt battery
I bought an extra clamp/rubber bushing that routes the cable away from the pedal assembly, used the extra rubber bushing on the negative cable where it crosses in close contact to the hold-down frame. I was making replacement cables, so the rubber bushing slid over the new cable easily. If you install on existing, just slice half and it will wrap around the cable nicely.. kb
1928 "A" Phaeton (mid year with many early features) 1933 "V8" Closed-Cab Pickup Truck (originally a Model B, 4 Cylinder dating to May, 1933)
I just took the grinder to it.
Here is my homemade battery clamp. It is made from 5/16" diameter steel rod with washers MIG welded to each end. Besides buying the rod, you can obtain it by repurposing a brake rod, or repurposing a radiator support rod.
Bob Bidonde |
I use a short length of garden hose and slip it over the battery cable and up to and over the part of the clamp that comes close to the hold down. Also watch the swap meets for the old, red plastic group 1 hold downs. They work nice and are non conductive.
I had the same concern. Went back to the original style hold-downs on the corners
Thank you all for the ideas. It is nice to know that it is not just me. The original designed corner hold downs do not work on the new style batteries that are in my cars. The new batteries are a little smaller than what I believe were original to the car. I do agree that the corner hold downs would be my preferred solution, they just need to extend over the top of the battery a little further.
Steve
With your knowledge and skills you can extend the original ones. |
