Old 04-11-2023, 08:34 PM   #1
walls
Default Stupid rear end question
Is there a way without taking apart or driving to tell the condition of a rear?
I have two and want to start taking the brakes apart and cleaning.
Just not sure if one is in better shape than the other.
Thoughts or advice?
File Type: jpg B6AF5369-62C5-478C-9FF2-883E9EA74012.jpg (164.5 KB, 70 views)
File Type: jpg A272405D-7894-4EBB-AFF1-7BA996986528.jpg (160.8 KB, 51 views)
walls is offline   Reply With Quote
Old 04-11-2023, 09:09 PM   #2
Sunny the Model A
Sunny the Model A's Avatar
Default Re: Stupid rear end question
if you can, open the drain plug and shine a light inside, if you see rust, walk away. spray brake parts cleaner in the hole, plug it and shake it up a bit, drain into a bucket and see if you see the forbidden glitter, if so, run. otherwise, go for it.
"Ain't but three thangs in this world worth a solitary dime, but A Models, Sweet Tea, and Macaroni Pie!"
Sunny the Model A is offline   Reply With Quote
Old 04-11-2023, 09:23 PM   #3
Brian SATX
Brian SATX's Avatar
You may also want to check the ratio to see which one will better fit your needs. You cna do it by marking a tooth and slowly rotate it and count the number of reves the brake drum makes vs the ring gear.
Brian SATX
Brian SATX is offline   Reply With Quote
Old 04-11-2023, 10:18 PM   #4
Y-Blockhead
Y-Blockhead's Avatar
Or count the teeth on the ring gear. Most common ratios; 39=3.55, 34=3.78, 37=4.11,
Old 04-11-2023, 11:08 PM   #5
J Franklin
J Franklin's Avatar
It doesn't take much time to pull one side off and check thorouly.
Old 04-12-2023, 03:49 AM   #6
walls
Thanks for the replies.
I’m thinking this is the best idea, but a little intimidated to be honest.
I’ve never opened one up before.
Words of wisdom?
Can I inspect without messing with anything critical?
I checked the one repair manual I have and not much on the rear.
Old 04-12-2023, 10:09 AM   #7
Tom Endy
Tom Endy's Avatar
Words of wisdom?
Here is a link to a rear end rebuild tutorial.
http://www.santaanitaas.org/wp-conte...vised-2014.pdf
Tom Endy
Old 04-12-2023, 10:25 AM   #8
Bob C
Just remember you have to deal with the rear spring so
be careful.
Bob C is online now   Reply With Quote
Old 04-12-2023, 10:31 AM   #9
rotorwrench
rotorwrench's Avatar
As mentioned, remove the spring with a spreader and some care first. The hubs & axle keys will need to be removed to disassemble them. Once that is done, remove the left side bell from the center banjo and mark it for left side in case the whole unit is disassembled. The whole final drive assembly can then be pulled out in one piece. The torque tube and drive shaft with pinion can be removed before or after but the left radius rod has to be removed to pull the bell off for just an inspection or minor repair.
The only stupid question is the one you should have asked but didn't. Your question is completely valid for a first timer.
Old 04-12-2023, 10:33 AM   #10
katy
katy's Avatar
You're gonna need a spring spreader for the rear spring.
katy is online now   Reply With Quote
Old 04-13-2023, 07:18 AM   #11
walls
I’m going to dig in this weekend and see what I find.
While we’re discussing, is there anyone in Philly/Allentown/Lancaster PA that can rebuild for me if these are not in the best shape?
If that’s the situation I find myself in, I might want to use a 3.54 gear to get a couple more mph.
