Old 06-28-2024, 10:54 AM   #1
Keith
Default Tire balancing beads
Just mounted a set of new tires 19" on my sedan and for the first time over many tire changes that I have done over the years I am getting a bounce on one of the front tires. Do the glass tire balancing beads work?
Keith
Keith is offline   Reply With Quote
Old 06-28-2024, 11:23 AM   #2
alexiskai
alexiskai's Avatar
Default Re: Tire balancing beads
They do. They're a pain to install though.
Old 06-28-2024, 11:24 AM   #3
1931 flamingo
1931 flamingo's Avatar
Yes, BUT I'd check for an out of round tire first.
Paul in CT
Old 06-28-2024, 11:38 AM   #4
Robert/Texas
Robert/Texas's Avatar
Swap the errant wheel and tire with one from the rear. I had this problem some years/decades ago and that worked for as long as I had the car.
Robert/Texas is offline   Reply With Quote
Old 06-28-2024, 07:28 PM   #5
Kurt in NJ
Kurt in NJ's Avatar
let the air out and break the beads,spin the tire a half turn and see if it is better.
A lot of times moving the tire on the rim can eliminate the need to balance.
Old 06-28-2024, 08:19 PM   #6
nkaminar
nkaminar's Avatar
The tire can be out of round if part of the flap is stuck under a section of bead.
I have had good luck with the stick-on lead weights. Back off the brake adjustment and back off the bearing nut a little bit until the wheel rotates freely. Rotate the wheel twice and if it stops in the same place, add weight at the top. Add the weights at the inside rim and clean the wheel before adding the weights. If you keep track of how much you backed off the brake adjustment and bearing nut, you can easily return them to their original position. Keep adding weight until the tire stops at random places.
The balancing beads work if the tire runs true, not out of round. It works at higher speeds and not at slow speeds. It works because at higher rpm than the critical speed the light side of the tire rotates at a bigger radius than the heavy side. So the beads migrate to the light side to balance the tire.
Old 06-29-2024, 12:47 AM   #7
Y-Blockhead
Y-Blockhead's Avatar
Altho I do run balancing beads, I would do a Kurt in NJ suggests. But first check for out of round, no method of balancing is going to correct for an out of round wheel/tire.
Old 06-29-2024, 04:42 AM   #8
Keith
Thank you all for the responses, I will first try deflating breaking the bead and rotating the tire on the rim. If no improvement than I'll try adding weights
Keith
Keith
Old 07-01-2024, 09:14 AM   #9
Bob Bidonde
Bob Bidonde's Avatar
I have some concerns about glass balancing beads. (1) Do the beads wear the inner tubes making them thin? (2) How long do the beads last? I assume the beads eventually breakdown into a powder? (3) Do the beads fowl the air valve in the tubes?
Bob Bidonde
Old 07-01-2024, 11:21 AM   #10
Fhane
Fhane's Avatar
The better beads are ceramic. I have been selling them for 20 some years. I have never seen ceramic beads turn to dust or wear a tube. Glass bead could be a different story.
Fhane is offline   Reply With Quote
Old 07-01-2024, 05:19 PM   #11
Werner
Werner's Avatar
Originally Posted by nkaminar View Post
... It works because at higher rpm than the critical speed the light side of the tire rotates at a bigger radius than the heavy side. So the beads migrate to the light side to balance the tire.
Guten Abend.
I don't understand that. It is clear that a tiny little bump is created at the point where the tire has the heaviest weight. To put it in an exaggerated way, the tire forms an oval.
My logical thinking would suggest that the beads would collect there on the outside in the curve of the bump. Because that is where the circumferential speed is highest and where gravity then drives the beads.
Where is my thinking wrong, please?
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 07-01-2024, 05:51 PM   #12
nkaminar
nkaminar's Avatar
Werner,
Thanks for responding.
The fact that there is a phase shift above the critical speed was a real surprise to me when I took a dynamics course in college. It does not make sense to someone without the technical education.
Every dynamic system, such as a rotating tire supported by a spring system, has a critical speed where the deflection caused by the unbalance is greatest. Below this critical speed the heaviest part of the tire has the greatest radius and the balance beads will migrate to that spot and make the unbalance worse. But above the critical speed the situation reverses and the heaviest part of the tire has the smallest radius and the lightest part has the biggest radius. So the balance beads will migrate to the lightest part of the tire to balance out the heaviest part. The beads migrate due to the circumferential force. Gravity does not enter into the equation because the circumferential force is a lot greater than gravity, at least for the Model A tire.
I don't know at what speed the critical speed is in a Model A tire, but suspect it is somewhere around 30 mph or maybe higher. It will depend on the car too, such as how stiff the springs are and what condition the dampeners (shocks) are in.
I know it does not make sense from the perspective of flinging a weight around with a string, but the fact that there is a phase shift above the critical speed has been proven many times.
Old 07-02-2024, 09:14 AM   #13
Bob Bidonde
Here is another look at the phase shift that nkaminar discusses in Post #12. When an out-of-balance wheel bounces, there is a bulge in the tire at the heavy spot that causes the wheel to bounce. When the bouncing of the wheel becomes severe, a resonance occurs that significantly increases the bouncing. The phase shift occurs at resonance, when the heavy spot and the bulge have a separation between them as the wheel goes into severe bouncing (resonance).
Bob Bidonde
Old 07-02-2024, 03:35 PM   #14
Werner
Werner's Avatar
Thank you for your effort!
I must apologize, that my American vocabulary is not sufficient to fully understand the last two explanations. But it seems that the beads work, even if I don't understand why.
(In Germany, the rotary engine was invented in the 1960s by Felix Wankel + NSU car manufacturer.
The engine did not catch on. "Evil tongues" claim that this is because no one understood how it worked. But the principle still works well.)
Werner
Citroen 11 CV, 1947
