Old 04-11-2011, 07:41 PM   #1
kendall
Default 1949 head light switch removal
is there a trick to taking the head light switch out of the dash on a 1949 F1? after unscrewing the nut that holds the switch in, whats the trick at removing the knob to get it thru the dash hole?......is there a clip or button on the switch to remove the shaft?, or does the knob just pull off the stem to allow the shaft to go thru the dash hole.
kendall is offline   Reply With Quote
