Old 09-27-2022, 04:38 PM   #1
Ol' Ron
Ol' Ron's Avatar
Default The perfect "street engine"
I think it's time to build the perfect street engine! Good usable power and economy at a minimum of cost. There are enough guys here that build engines and have plenty of experience. I'm working on one now.
Gramps
Old 09-27-2022, 04:43 PM   #2
wga
wga's Avatar
Default Re: The perfect "street engine"
Ron, you following the recipe from your book?
Henry Ford designed the flathead without the aid of a computer.
wga is offline   Reply With Quote
Old 09-27-2022, 05:58 PM   #3
petehoovie
petehoovie's Avatar
Old 09-27-2022, 05:07 PM   #4
19Fordy
19Fordy's Avatar
That's great Ron. If possible, do a step by step build procedure and post photos on the Fordbarn.
Your knowledge and experience are " old gold" that needs to be passed on to the younger folks. Thanks.
Old 09-28-2022, 06:14 PM   #5
Ol' Ron
Ol' Ron's Avatar
I get quite a few questions from some of the readers her about rebuilding their engines, and what to do to make them better. What modifications to make, etc!! I think most of the guys are refering to a stock engine rebuild. If You have an issue of JWLs book, the first thing he does id give the torque and Horsepower of the stock engine. He goes on to make some modifications to the exhaust system. In Any case the engineonly produced 80 HP and 150ft of torque at 2000 roms. Max HP is at 3000rpms with oly 133 ft lbs of torque. This is a very inefficent engine and not much can be done to improve it. my first suggestion is to bore it to 3 5/16. This will increase the CR to 7.7:1 using EAB 74cc Heads. This will add about20ft lbs of torque. Doesn't sound like much, but will be felt in low speed acceleration, but mostly at the gas pump
Tuning th e engine is where most people drop the ball. How many people have an AF meter?? Their not expensive and you need to know this information. An inexpensive intake with a late 1/16 Holley and aload amatic distributor. The expense if a 4bl or 2 ducejust adds $$$$$$ and don't offer much in performance and economy and you'll need one of Charly's disributors, Probably shouldget one anyway.
Now Lets hearsome other suggestiond. This is a bottom line "Street engine" But it will run that old Ford DDR at 70 mPH all day long.
Gramps
Old 09-28-2022, 07:12 PM   #6
3twinridges
3twinridges's Avatar
I have an 8BA in our 52 F1. 4” crank, bored 60 over, 1CM cam, and 8ba heads milled. Stock distributor and carb and it pulls strong. Easy to tune and no fancy parts. I did convert the air cleaner to run a K&N filter. Everything looks stock on the outside, but when you crank it, you can tell it has more than the average Joe.
JB
3twinridges is offline   Reply With Quote
Old 09-29-2022, 07:02 AM   #7
Tim Ayers
JB
Love it. That's my kind of motor.
Old 09-29-2022, 07:00 AM   #8
Tim Ayers
I'd be interested in this and what the final outcome is.
I may have a different mindset than others when rebuilding a motor.
While it's apart (which is the hardest part of the job), why not try to get the most of out if for your application?
Meaning: If it's a truck that's going to be used as a truck, get as much torque out of the motor as you can.
If it's a street car, get as much fun out of it as you can.
There are things you can do that don't cost money. Ex: Porting the exhausts and intakes runners is relatively free. If you don't have a hand grinder, even the cheapie Harbor Freight job will do. Why port it? For the reason Ron mentioned. To help it be more efficient.
It's a fun job to do and you'll learn something along the way.
Doing what you can to get the block prepped for cleaning. Working to get those water jackets surgically clean is another "at home" job. Getting as much gunk out of the water jackets helps before the block goes in for a cleaning. Baked and blasted and chemically dipped or washed.
You will be amazed as to how much crud and, sometimes, casting sand comes out of the water jackets.
This is essential in order to get a cool running motor.
Other things just make sense after knowing what we know today. EX: Using metric rings packs to help with efficiency and reduce wear. You'll need to buy pistons for the rebuild anyway, so why not use modern technology to help get a little more out your engine?
Using three ring pistons instead of four. Why? That fourth oil ring has been proven as not needed on a fresh rebuild and only causes more drag and wear.
Using a torque plate when honing. Why? Getting the bore as perfectly round as possible helps with wear and efficiency.
Like JWL's book mentions, picking up little gains along the way eventually add up to a big gain.
Old 09-29-2022, 12:35 PM   #9
slowforty
slowforty's Avatar
Porting will teach you how to weld up holes in cast iron.
slowforty is offline   Reply With Quote
Old 09-29-2022, 12:39 PM   #10
Tim Ayers
Haha. If one has an aggressive, heavy hand could be. I bet you learned from it though, right?
Old 09-29-2022, 03:30 PM   #11
Ronnieroadster
Ronnieroadster's Avatar
Certainly true if you don't know what your doing especially when it comes to thinking your going to weld holes in cast iron!
Its like if you don't know how to do plumbing you have a professional do it. Or else your going to need a sump pump. When it comes to porting porting read, learn, ask and practice and then all will be good.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Old 09-29-2022, 05:59 PM   #12
Ol' Ron
Ol' Ron's Avatar
One thing about porting, It offers very little in the low and mid range . Plus asmall displacement engine has enough port for the application. Now if you have a flow bench and plan on running at Bivlle??
Old 09-29-2022, 07:20 PM   #13
Tim Ayers
What do you consider small displacement? The proposed 258ci engine?
I'm interested in hearing more about your comment regarding low & mid range.
A few thoughts, what does that entail? Very few cars drive around for any extended period going slow. They generally get up to speed (45-75) for most of the time while driving.
I had the luxury of having a junk block around and I cut open the block at the end ports. I would really like to see some flow test data with a worked over motor that was ported vs. the exact same motor without being ported.
Maybe that information is in John's book. I haven't read it a few years and will go back to look at it again.
I'm really interested in seeing data of how improving the flow out of the end ports has little benefit.
This is a fascinating topic to me and I'm trying to soak up what I learned with my recent build and what to do next for my future 99A build up.
Old 09-29-2022, 08:28 PM   #14
Pete
One thing about porting, It offers very little in the low and mid range . Plus a small displacement engine has enough port for the application. Now if you have a flow bench and plan on running at Bivlle??
Very true. A MILD street engine only needs port matching and very mild decobbing.
Even an all out engine will not benefit much if any, from a flow bench any more.
Flathead ports flow more the bigger you go and if you go to .090 wall all the way through the port with a sonic gauge, that is about all you can do unless you go to installing steel tubing for ports.
Old 09-29-2022, 07:46 PM   #15
Flathead
Flathead's Avatar
Seems to me that if breathing is the big problem with a Flathead then there would be a place for some judicious metal carving.
Flathead is offline   Reply With Quote
Old 09-30-2022, 01:06 AM   #16
Lawrie
Lawrie's Avatar
the engine in my 33 is 265 ci. a 99a block .040 with a 4in crank, I used the stock 33 cam and inlet manifold ,a new 97 carb, it will run all day at 50-55 mph with the caravan on the back and is one nice engine,
I know it would be better with a different cam and bigger carb But for my application its really good,
I set up the carb using an O2 meter.
Lawrie
Old 09-30-2022, 07:55 PM   #17
Ol' Ron
Ol' Ron's Avatar
if, a big IF you consider what moves your car , and how fast it accelerants. You must consider TORQUE, and BIG engines make large amounts of torque. Or do they When you get your dyno sheet with the torque readings, you can see them start to fall off very quickly with a flathead. Yet when you run a sBC the torque curve cintinues along for quite awhild, befor falling off. I had this exolained to me once by the dyno Teck as the breating of the engine had reached it limits. In other words the ports could noe move more air. In johns book he shown that at 2000RPM the engine was recieving all the air it could use, but at 3000 RPN, the port couldn't supply any more air, thus the power was down. But the formula for hP provided more HP
In order for a engine of any kind t make 200 HP it has to cary the torque to a much higer RPM range. OR supply more aqir. It's the only thing thst makes power.
Gramps
I just read this and don't understand a thing I said.
G
Old 10-01-2022, 05:07 PM   #18
47topless
47topless's Avatar
Talking Re: The perfect "street engine"
G[/QUOTE]
Thank you for making me laugh on a day with such terrible news from everywhere.
Phil
47topless is offline   Reply With Quote
Old 10-01-2022, 01:07 AM   #19
Brian
Brian's Avatar
The ports and valve sizes remain much the same throughout the entire flathead engine series, irrespective of engine displacement. There is a limit to how much these can flow. Once this limit is reached, with the larger displacement flatheads, you obviously are not going to be able to completely fill the cylinders. Therefore, the smaller displacement engines must be more efficient? I'm talking naturally aspirated.
Old 10-02-2022, 01:35 PM   #20
Ol' Ron
Ol' Ron's Avatar
If you think the ports are too small, all you have to do is add a supercharger. % lbs of boost will make more power tham a Bored and stroked L-100, try carbe engine any day.
So drag out those old blowers and bolt hem on. The only thing you need is a timing lite and an AF meter.
Gramps
