Old 02-08-2022, 03:19 AM   #1
dave in australia
Default Timing Gear
I caught my timing gear just in time. The engine developed a rumble, so I pulled the side timing cover off, and by luck, the chipped tooth was lined up so I could see it. Replaced it with an aluminium one and a new crank gear.
dave in australia is offline   Reply With Quote
Old 02-08-2022, 04:11 AM   #2
mercman from oz
mercman from oz's Avatar
Default Re: Timing Gear
Not good - Glad you picked it up in time.
Old 02-08-2022, 11:04 AM   #3
katy
katy's Avatar
Does the aluminum gear make any noise? I've read that some do and some don't.
Old 02-08-2022, 11:49 AM   #4
PC/SR
Noise from a metal timing gear depends on how they fit. There should be .003-4 clearance with the crank gear. After who knows how many babbitt jobs, normal wear and tear, etc , the crankshaft may not be exactly centered and the fit with the cam gear is off. Dan McEachern makes both over and undersized gears so you can get a proper fit.
PC/SR is offline   Reply With Quote
Old 02-08-2022, 08:01 PM   #5
BTERRY29
BTERRY29's Avatar
Dan's gears are a thing of beauty.
BTERRY29 is offline   Reply With Quote
Old 02-08-2022, 10:39 PM   #6
CarlG
CarlG's Avatar
They definitely are! I have his bronze gear with the matching crank gear. They run smooth as silk.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 02-10-2022, 10:17 PM   #7
mgambuzza
mgambuzza's Avatar
On mine I was getting an intermittent clank when idling. It would increase as it warmed up. Mine was a fiber gear, and when he showed it to me the bolt holes were worn like a good and plenties. He replaced it with an aluminum from Snyders. I haven't noticed a significant increase in noise although it is the winter season in Upstate NY. The times I have let it run to warm up I didn't notice it any louder than in the past. Good catch on identifying and replacing before something more catastrophic happened!
mgambuzza is offline   Reply With Quote
