Old 01-14-2022, 07:05 PM   #1
bo8109b
bo8109b's Avatar
Default Banjo Bolt
3rd Gen is offering the Banjo Bolt for the oil return from the oil cannister but not the banjo fitting that connects to that 1/4" line. Is that fitting available somewhere? Carl
bo8109b is offline   Reply With Quote
Old 01-14-2022, 11:37 PM   #2
lgndlt5
Default Re: Banjo Bolt
Ahh!! I have searched for months also. None I have found will fit the OD diameter of the bolt. 5/16 “ a if memory serves. I bought a brass brake fitting from an early Porsche 911 with an ID that has a larger ID than the that bolt and will try to find copper tubing that fits their or is slightly larger OD the sand the tube incrementally until it fits the ID of my banjo fitting. I will then braze it in place, trim any excess that protruded out of the banjo end and hope for the best.. Mart on thi board found an offbeat old Skoda brake banjo that he made function for this purpose. It was in his saved junk pile. Searched for it and had no luck. Good luck let me know if you have any success. The line and fitting manucturers all declined queries for a proper size banjo. Still searching. Let me know..(Lgndlt5). Stalled for now! John
lgndlt5 is offline   Reply With Quote
Old 01-15-2022, 10:54 AM   #3
HD Rider
The original fitting was actually a hose end that was crimped to the hose.
My solution was a hydraulic adapter but brace yourself. Hydraulic fittings/hoses/adapters are not cheap.
https://www.summitracing.com/parts/fra-980361-bl
You will need the 5/16 banjo bolt from 3rd Gen.
This one looks like a better option.
https://www.summitracing.com/parts/vpe-24041
You'll need appropriate hose and hose ends/fittings to make this work.
Paul
HD Rider is offline   Reply With Quote
Old 01-15-2022, 10:56 AM   #4
HD Rider
Here's a couple of pic of mine.
