Old 12-03-2021, 10:12 AM   #1
32truck
32truck's Avatar
Default Aluminum pulley for M90 blower.
Well while I have the distributor out waiting for charlieNY to check it out, on to the next issue. My blower pulley is damaged because some numb nuts didnt have it tight and wallowed out the keyway. Any ideas where to get something like this? I know it's a v belt on a blower but I'd rather not completely change the belt set up.
Andy
Sent from my SM-N986U using Tapatalk
32truck is offline   Reply With Quote
Old 12-03-2021, 11:02 AM   #2
Bored&Stroked
Bored&Stroked's Avatar
Default Re: Aluminum pulley for M90 blower.
You'll probably need to have one custom made at a machine shop. Not a hard thing to do - but they'll need exact measurements on the shaft and keyway.
Old 12-03-2021, 11:56 AM   #3
marko39
What is the pully diameter? And bore? Does it have to be aluminum ?
marko39 is offline   Reply With Quote
Old 12-03-2021, 11:58 AM   #4
Brian
Brian's Avatar
Or, [machine work again] simply bore it out, press in a sleeve, [ideally steel - more durable], scotch key it in place, bore and key it to suit...
Old 12-03-2021, 12:36 PM   #5
solidaxle
solidaxle's Avatar
Consider yourself lucky it didn't fly off going down the road.
solidaxle is offline   Reply With Quote
Old 12-03-2021, 12:37 PM   #6
32truck
32truck's Avatar
Bore .640 pulley diameter 4inches. Nah doesn't have to be aluminum.
Old 12-03-2021, 12:38 PM   #7
32truck
32truck's Avatar
No doubt!
Old 12-03-2021, 12:40 PM   #8
32truck
32truck's Avatar
Yeah I do have a lathe, so I was thinking about that. I don't have an end mill though. Still may attempt this.
Old 12-03-2021, 12:41 PM   #9
32truck
32truck's Avatar
I've been calling around to a few machine shops without any luck yet.
Old 12-03-2021, 01:51 PM   #10
marko39
That is an odd bore size .640 = 41/64. Is that the shaft size? If it is 5/8 ( .625) I can probably help. Worst case would be boring out the 5/8 to 41/64.
Old 12-03-2021, 02:27 PM   #11
32truck
32truck's Avatar
Yep Shaft size is .640
Old 12-03-2021, 02:50 PM   #12
Bored&Stroked
If it was mine, I'd make a steel blower drive flange - similar to a crankshaft blower pulley flange. The flange would have bolts to bolt on an aluminum pulley. This way you can change pulley sizes quite easily. The flange should have a centering ridge on it (like a crankshaft blower pulley).
Old 12-03-2021, 02:51 PM   #13
Bored&Stroked
Also, you might consider using a dual-belt lower pulley - if it will clear your cross-member. It is much better to have multiple belts than just one. If you're going to the trouble of coming up with a new pulley drive system, might as well make it better.
Old 12-03-2021, 03:10 PM   #14
Pete
Old 12-03-2021, 03:48 PM   #15
32truck
32truck's Avatar
Definitely like this idea. Actually this makes the most sense. Definitely looking into this. Thanks so much. I agree this is a poor design.
Old 12-03-2021, 03:50 PM   #16
32truck
32truck's Avatar
I have about a 16th of an inch clearance with the crossmember unfortunately.
Old 12-03-2021, 04:27 PM   #17
marko39
The last piece of the puzzle is what size is keeway and are you using an A belt or B belt?
Old 12-03-2021, 05:48 PM   #18
32truck
32truck's Avatar
Not sure on the size of the keyway. I will measure it over the weekend. Its at my shop. Thanks.
Old 12-03-2021, 06:36 PM   #19
Ggmac
Cant you cut another slot say at 180 degrees . If its not timing anything , Ive done this on a few shafts that were messed up .
Old 12-03-2021, 06:39 PM   #20
32truck
32truck's Avatar
Great suggestion, but unfortunately the entire hole got wallowed out.
