Old 07-21-2021, 09:18 AM   #1
rer_239
rer_239's Avatar
Default Clutch
It looks like the clutch can be adjusted in place thru the inspection square hole, can enough of the clutch disc be seen to evaluate it?
rer_239 is online now   Reply With Quote
Old 07-21-2021, 09:34 AM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Clutch
The clutch free-play is adjusted using the adjustable linkage between the pedal link and clutch arm just outside the bell housing/clutch cover.
The pressure plate fingers can be adjusted, if necessary, inside the inspection cover. But, shouldn't need to be touched.
The overall inside condition can be somewhat looked at thru the inspection cover.
The release bearing collar can be greased inside that cover. Just a pump or 2 is all thats needed.
Old 07-21-2021, 09:50 AM   #3
rer_239
rer_239's Avatar
Default Re: Clutch
Thanks
